2015 Winter Wheels
Results 1 to 15 of 18
This is a discussion on 2015 Winter Wheels within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Admins I know this should be in the Suspension & Wheels section but I wanted to start it hear so ...
    Jan 2012
    New Jersey
    2015 Winter Wheels
    Admins I know this should be in the Suspension & Wheels section but I wanted to start it hear so that It wont get buried. If you guys dont mind leaving it for a few days to build up some conversation then movie it or what ever you guys plan to do.
    I know that since its Spring and not many people want to think about Winter but before the mods start coming out some people may want to put some of that extra money aside for winter wheels and tires. Now I know that they changed the bolt pattern on the 2015 WRX and the budget tire rack steel wheel option may now be out of the question this could be a possible solution.
    From this thread on IWSTI the 07 + Honda CRV steel wheels appear to fit and clear the STI Brembos so they should work on the new 2015's. Now I dont have a 15 so I am not 100% it will work but if it woks with the older STI's I dont see why it wouldn't work. If someone with better knowledge please correct me if i'm wrong.
    New winter steel wheel solution - Pics!!!!! - Subaru Impreza WRX STI Forums: IWSTI.com
    CFLip2x 2012 WRB WRX Build
    Registered User Raven Logics's Avatar
    Dec 2007
    Canada
    If you want 17's then just go onto tire rack and use the 2014 STI as a vehicle. There are a few inexpensive alloys on there you could consider.
    Apr 2014
    BROlando
    Bump. This thread is incredibly relevant to my interests.
    I am kind of hoping people dump their OEM rims for me to pick up on the cheap. I like em, and I know they are polarizing at best.
    Sent from my DROID RAZR HD using Tapatalk
    Cee
    Cee is offline
    Registered User Cee's Avatar
    Apr 2014
    Columbus, Ohio
    I'm also looking to pick up a pair of 18" Rims and Winter Tires for my STI. It doesn't look like TireRack supports the 2015 for rims yet. =/
    Registered User gizmo0034's Avatar
    Apr 2014
    evanston, il
    I'll probably be selling my OEM WRX wheels when I get the car next month. I was planning on using them for winter wheels but since I dont drive very often, I might just get a set of 18" winter tires for the bbs wheels I bought.
    Registered User jsantos1082's Avatar
    Aug 2012
    River Edge, NJ
    what are the bolt patterns for the 15s?
    JOE
    2013 WRX DGM
    Stink Eye Mob #82
    Aug 2012
    Tucson, AZ
    Same as the sti now
    Sent from my SCH-I545 using Tapatalk
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Jun 2014
    I have a set of CR-Z rims with winter tires 205/55/16 (~35lbs tire + wheel). I was told that 16s will fit WRX but not on STIs.
    I took a quick peek at front break and seems there arent much room between caliper and the stock 17" wheel. did anyone try to fir 16s in the front?
    May 2014
    Hampden Maine
    Quote Originally Posted by cflip2x View Post
    May 2014
    Hampden Maine
    Just checked with Subie dealer. 17" steel wheels are not available. Also plan on 4 TPM's for any new wheels.
    Probably cost 1200-1500 for decent tires/wheels/tpms.
    I might just buy winter tires and swap each year, eventually using stock wheels for winter, and then next spring invest in new wheels.bound to be a larger selection then. Who knows?
    Guzziman
    Mike
    Jan 2012
    New Jersey
    If you get the TPMS see if they would have to recalibrate it each time you swap out wheels. I just put up with the low tire pressure light. Some of the CRV wheels are steel wheels not the traditional ones most think of (cant take hubcaps).
    Aug 2012
    Tucson, AZ
    You'll need to reprogram the sensors for each set of wheels installed at each time you swap them. You'll also need to check and see if subaru even has a set of sensors that will fit correctly in the other wheels
    Previous cars:
    2009 WRX (sold )
    IG - kevinrimcoski
    Jul 2014
    Quote Originally Posted by wkqkqkfk View Post
    Any updates? Will 16" wheels fit on the 2015 WRX? I have a set of winter tires on 16" steelies if they work that would be awesome
    Jun 2014
    the 16" CRZ rims did not clear the front brakes. it goes in but the inner wall of the rim very slightly touches the brakes. some 16" rims may clear the brakes but I think you have to try them on.
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    Try Sullivan tire.com. Or Town Faire tire. It's easiest to swap wheels than tires. Plus the sensor issue, and rims can get beat up with tires going off and on. I have 17" alloys with Yokohama winter tires. It takes 10 mins to swap them. Just a suggestion.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
