What is this noise?!?
Results 1 to 11 of 11
This is a discussion on What is this noise?!? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Ok, I have a 3 month old 2014 wrx and it started making a high-pitched grinding noise from the left-front ...
    Jan 2014
    The Triangle
    Ok, I have a 3 month old 2014 wrx and it started making a high-pitched grinding noise from the left-front wheel
    Kind of like the sound of resurfacing rotors. Whenever the wheel is moving it makes the noise. Whats worse is when
    I'm turning (+~45 degrees) it makes a clanking sound. The dealership is closed Sundays. I'll be stopping there first
    Thing in the morning. But does anyone have insight? Has this happens to anyone
    Else?
    Feb 2014
    PNW -WA STATE - rainy side
    No, but could be a sticky caliper or broken brake part. Does it follow wheel speed?
    Jan 2014
    The Triangle
    The faster I go the louder it gets. Brake pedal is normal.
    Feb 2014
    Does it change when you touch the brakes?
    Jan 2012
    New Jersey
    Sounds like it could be a piece of gravel stuck between your rotor and dust shield or rotor and brake pad.
    CFLip2x 2012 WRB WRX Build
    Jan 2014
    The Triangle
    I was thinking that too, I just noticed that it gets MUCH quieter when I turn to the right +~30 degrees
    Jan 2014
    The Triangle
    And it makes no difference if I hit the brakes.
    Jan 2014
    The Triangle
    It was a rock!
    Feb 2014
    Sweet.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    Jan 2012
    New Jersey
    Its happened to me 4 times or so really scary noise. Im always afraid something is falling off the bottom of the car but I always look around and see all the gravel and I know it will eventually go away.
    Registered User Ampliified's Avatar
    May 2012
    Warren Twp, NJ
    This seems to be a reoccurring problem for our models wonder if the manufacturer will do anything about it because I'm sure that this will decrease brake life and it only happens to my front left aswell
    2012 DGM WRX - Stage Two 93 - Stink Eye Mob #908
    The Epic Life of Emily the WRX
