Whats wrong with my brakes
Results 1 to 4 of 4
This is a discussion on Whats wrong with my brakes within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; hello, I drive a2007 wrx with about 60 000 miles and tonight on my way home my brakes started to ...
    Mar 2014
    hello, I drive a2007 wrx with about 60 000 miles and tonight on my way home my brakes started to feel like my discs were warped, which is weird cuz I just changed them last week.
    I stopped to get gas then when I left the gas station I notice I had to push the pedal to the floor to stop the car, so when I got home I saw a lot of smoke coming off the right front side of the car, I took of the wheel and the heat coming from the brakes was intense, so hot that the paint on my calipers started peeling off.
    I don't see any leaks and the pedal gets hard after a few pumps.
    anyone have any ideas of what the problem could be?
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Try rebleeding the brakes. Did you properly bed in the pads?
    When I followed the bed-in procedure for my Hawk HPS pads, all four calipers had smoke pouring out of them. After letting the car cool for 30 minutes, the pads were properly bedded, and never had a problem after that.
    2007 Outback 3.0R wagon
    Registered User mmiller2002's Avatar
    Nov 2007
    Ft. Worth, TX
    It sounds like the pads were dragging. Maybe the caliper is seized. Try bleeding and see if the caliper cylinders move properly.
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
    Palmyra, NJ
    Also given the fact that you probably need to rebleed the brakes, and the characteristics you described, you probably didn't bed the pads in that well either (if at all).
