What sway bars and end links did you get? - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 56
This is a discussion on What sway bars and end links did you get? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by wreckingball man Whiteline are probly the most popular. Eibach, Rallitek, and Hotchkis are good too. Kartboy makes ...
    Registered User frenziedcage's Avatar
    May 2012
    Colorado
    Quote Originally Posted by wreckingball man View Post
    Kartboy makes the cheapest solid endlinks I believe and they're also very popular.
    Agree.
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Quote Originally Posted by kprugbyplaya View Post
    damn. you beat me.
    And I beat you both to it.
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    Quote Originally Posted by A265 View Post
    Well you always beat me...
    ¯\_(ツ)_/¯
    Kunal - Ordered 2015 DGM WRX
    Photographer | Dancer | Tech Nerd | The Stink-Eye Mob #7
    First Mods: What and what not to do
    2011+ Big Mod Thread
    How to Buy a Used WRX or STI
    Complete USED WRX Buying Checklist
  6. #19
    Registered User Brazilnut's Avatar
    Jul 2013
    Colorado
    Quote Originally Posted by dknow View Post
    Hello all,
    I have a 2014 WRX Sedan that is my daily driver, will not see a track just street fun. I was looking to upgrade my sway bars and end-links and was wondering which brand you have and size.
    I was thinking about whiteline 22mm adjustable rear and 24mm adjustable front. and karboy endlinks.
    But i also seen the eibach swaybar kit that comes with 25mm adj front and 22mm adj rear. for about $366. plus tax
    just what to know if you are happy with the swaybars and endlinks you purchased.
    Thanks
    Dknow, yaknow, I have that exact set-up you've been eye-humping. But you know what they say... bigger is ALWAYS better, so I say go 24 both front and rear and call it a day.
  7. #20
    Mar 2009
    in a igloo
    Quote Originally Posted by Brazilnut View Post
    That's not exactly true when it comes to sway bars, if you get a huge bar and you're springs are too soft you will experience wheel lift in times you don't want.
    That being said, a 24mm bar isn't that huge, but it is the biggest bar I would run on stock springs.
  8. #21
    Registered User dknow's Avatar
    Aug 2013
    Downers Grove, IL
    So you recommend 24mm on front and back?
    or should i get 22mm front and back?
    or just stick with my original order i was looking at, which is 24 front 22 back
    14 WRX SWP Sedan
    Fog lights, Short throw shifter, SPT Exhaust,
  9. #22
    Mar 2009
    in a igloo
    I have 24mm front and 22mm rear solid bars (whiteline). They are not installed yet so this is research based recommendations.
    However this is my take on the 2 options I was considering, so it depends on how you feel your car is lacking.
    I autoX and find my car pushes out (understeers) and turn in is not as sharp as I'd like, this is why I decided to go with a bigger bar up front.
  10. #23
    Aug 2013
    Downers Grove, IL
    do you know what the stock sway-bar sizes are for the 2014
    14 WRX SWP Sedan
  11. #24
    Registered User soloz2's Avatar
    Jan 2011
    Western NY
    I read elsewhere they are 21/16 for the WRX. I have not measured mine as I've only had it just over a week, but I definitely think it could use a bit of an upgrade.
    Sent from my GT-N5110 using Tapatalk
    Current Rides: 05 Outback XT 5MT & 14 Forester XT Premium
    Past Subies: 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon
  12. #25
    Registered User derekd2222's Avatar
    Feb 2012
    Virginia Beach
    If you can get your hands on an STi rear sway bar they are 19mm and a good pair with the stock front (also look factory from under the car, if that's a concern). Definitely save some money that way.
    2011 SWP Sedan
    Tuned by Kienan @ All Aspects Motorsports: 350WHP / 375 ft/lbs TQ on E85
    http://www.clubwrx.net/forums/builds...swp-sedan.html
  13. #26
    Jan 2011
    Western NY
    The STI bar can be had for about $100. I put one on my wife's 14FXT and it made a substantial difference.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  14. #27
    Dec 2011
    Pottstown PA
    perrin 24mm front, perrin 22mm rear, whiteline rear sway mounts, kartboy endlinks. 02 wrx
    Marky Mark
    My bugeye build
    MinoskePhotography
  15. #28
    Aug 2013
    Downers Grove, IL
    The tuner shop I stopped at told me I should be fine with just changing the rear sway bar and end links. Told me to leave the front sway bar stock. What do u guys think.
    Sent from my SCH-I545 using Tapatalk
    14 WRX SWP Sedan
  16. #29
    Contributes Nothing ShiftingLanes's Avatar
    May 2013
    Riverdale, NJ
    This really depends on what you want your car to do. For optimal performance, change both at the same time. Front is also more important than the rear. Change the rear only, you'll change the way the car oversteers. Both at the same time is recommended.
    I have a '14 hatch and have 24/22 front/rear whiteline sways. Yet to install, but this was recommended to me by multiple tuners (including ones on this forum) and regulars here on this site.
    http://shiftinglanes.com
    '14 DGM WRX Limited Hatch
    I'm a build thread?
    Stink-eye Mob #49
  17. #30
    Jun 2013
    eibach sway bar kit (stiffest setting), and Kartboy end links. Perrin front strut bar too
