I want to go the other way - raise the car....brainstorming
Results 1 to 15 of 18
This is a discussion on I want to go the other way - raise the car....brainstorming within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; brainstorming in progress. Stand back, throw ideas in.... I want a more offroadable, rally type WRX 2014 WRX Hatch - ...
    Feb 2014
    PNW -WA STATE - rainy side
    Smile I want to go the other way - raise the car....brainstorming
    2014 WRX Hatch - say I want to raise the car 1" and maybe 1.378" in the rear. (Subtle Solutions)
    Stiffen it up with all the braces and put a bar and skid plate(s). You maybe can get a mental image. My questions (and I'm a bit tired from working my arse off all day):
    If I put some nice sway bars on would I need longer endlinks with a raised car?
    Pretty sure it retains the stock shock and spring MacPherson length.
    Can I still use most all the various stiffeners?
    What the heck am I missing??
    Jul 2012
    Rocky Top
    Think about where the sway bars are mounted. We'll set a datum at the body of the car and assume upwards the positive direction.
    In the rear, the endlinks mount to the lateral links. If you raise the car's ride height, the mounting point will travel down as you raise the car. So, in theory you would need longer endlinks or longer mounts on the lateral links. In the front, the endlinks are mounted to the control arms. So if you raise the car, the endlink mounting point will travel down again. So in theory you would need longer endlinks in the front as well. (correct me if I'm wrong, I just got done with a 7 hour long Calc and Thermo studying binge so I'm a little fried)
    Now, If you only raise the car about an inch or two I don't think it would really matter, but it couldn't hurt to research that topic over on dirtyimpreza.com or something.
    For skid plate, I've seen anything from old road signs like stop signs work well or whatever sheet of metal you can get. Again, I've seen tons of write-ups on making your own skid plate on dirtyimpreza.com if you want to make your own.
    Not sure about the new WRX's, but my friend runs forester struts on his bugeye (great upgrade and very cheap). You might look into that, see if there's an option similar to that for the '14. Otherwise there's plenty aftermarket springs out there for that purpose. Gregroot on here had a newer WRX that was a pretty sweet rally car. You might want to check out his build thread.
    Registered User gregroot198521's Avatar
    Feb 2011
    El Paso, TX
    Do you want a better ride too? If so, I'd suggest a set of King springs (give slightly more than 1" of lift and behave better than stock springs). Why are you wanting more lift on the rear? Uneven lift will mess up the aim of your headlights. This is all from experience too, by the way, I had my '11 WRX lifted with slightly more than 2" of suspension lift and ~1" of tire lift.
    With an inch of lift you will be just fine with stock length end-links, I ran the stock length Kartboy end-links the entire time I had the car lifted.
    FYI, I still have those springs (King progressive spring rate, ~1" lift springs) and various thickness spacers (Subtle Solutions 1" lift kit, 1/2" Paranoid Fabrications kit, 3/8 and 1/4" rear spacers) hanging out in the garage and looking for a new home.
    Hawkeye Alliance #1050
    Build Thread
    http://i1108.photobucket.com/albums/...ps665d9b9d.jpg
    Always dirty, never scurred......
    Feb 2014
    Quote Originally Posted by gregroot198521 View Post
    I assume I can re-aim my headlights - well the HID's - from the cockpit. More in the rear (1/4"-3/8") to even it up was my thinking. May not need this.
    But to the point. You had your car lifted, and you took it back down. (For trade in?) I get what you say in your thread, but how did your 2011 ride and go and handle?
    Thanks!
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    The new cars suck. All you have to do with the older model Impreza is swap Forester suspension over. Not sure if the same applies on newer models.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 2014 Hyundai Veloster Turbo (Matte Grey), 06 LGT, 98 RS, 16 Crosstrek
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Never argue with idiots. They'll drag you to their level and beat you with experience.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by Drews View Post
    It's more difficult, IIRC. There are challenges with the multilink suspension when lifting the car.
    You're not alone in wanting to lift the car. I've wanted to do the same on my bugeye for several years.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jan 2012
    Philly Area
    dirtyimpreza.com
    - Will
    Aug 2008
    Davey Jones Locker
    If you're too lazy to search DirtyImpreza.com - The Off-Road Impreza Community this is the thread I've gotten the best information from.
    The Unofficial "How to Lift your Impreza" Thread - DirtyImpreza Forums
    Obviously, this does not apply to your MY but should provide some good information on what you can do.
    Feb 2011
    El Paso, TX
    Quote Originally Posted by Oilypablo View Post
    Thanks!
    True, headlights can be re-aimed to a point. 1/4" extra in the back wouldn't cause too much issue I believe.
    Correct, traded in for my current dirty girl ('06 STi). The 2011 rode great on those springs alone, spacers didn't really change the feel too much. Granted I wasn't trying to put it sideways around corners, lifted, I'm sure it decreased the max speed I could do around a corner. So, I guess I'd say ride quality went up, handling went down a little bit for quick and sharp maneuvers, though I did plenty of those in the desert. No problemo.
    Build Thread
    Registered User atranz's Avatar
    Aug 2012
    houston, tx
    Im looking to do the same thing. What tires are you considering? Anyone with pics?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Aug 2008
    Davey Jones Locker
    Quote Originally Posted by atranz View Post
    Did you bother looking at the link I posted?
    Aug 2012
    houston, tx
    Yes I did. It seams dirtyimpreza forum has more of the "impreza" and older models cars. Im looking for 2008-2014 wrx/sti's.
    Aug 2008
    Davey Jones Locker
    You are aware that the 2008-2014 WRX/STis are the Impreza, right? Maybe you should try the search function on that site...it might get the results you're looking for.
    Jan 2012
    Philly Area
    Start a thread. I know there are some 3rd gen guys on there. And guys who maybe don't have 3rd gens but do have the knowledge you seek.
    - Will
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Anyone interested in lifting a Subaru should talk to Primitive Racing. They sell King spring packages, and have proven rally experience on Foresters, Imprezas, and Outbacks. I will most likely be sourcing my suspension from them (although I'm lowering the Outback to LGT height).
    2007 Outback 3.0R wagon
