Lowering springs with stock shock observers?
Results 1 to 13 of 13
This is a discussion on Lowering springs with stock shock observers? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hello Is it ok to replace stock springs with lowering springs without the replacement of stock shock observers? Is the ...
    Dec 2013
    Hello
    Is it ok to replace stock springs with lowering springs without the replacement of stock shock observers? Is the aftermarket coilovers harder then the stock ones?
    my wheels are 18x9.5 ET35 tyres 235/40/18 all around.
    I do not know if I can find here in the UAE any body how can do fenders rolling. Click image for larger version.
    Jul 2012
    Rocky Top
    There are certain springs that will work with the OEM shocks/struts. Not sure what you can get over in the UAE though.
    Registered User Wrxchick1676's Avatar
    Feb 2014
    NJ
    I was looking into getting the Eibach pro kit springs . I have stock wheels struts n shocks
    Palmyra, NJ
    You should put on some tires that fit before you get any kind of springs.
    Feb 2014
    NJ
    When I got the car , I had brand new tires put on . What kind of tires do I need?
    Jul 2013
    Silicon Valley
    Quote Originally Posted by Wrxchick1676 View Post
    I'm guessing this was directed at OP. Look at that first pic.
    Palmyra, NJ
    Quote Originally Posted by Zataks View Post
    This.
    Palmyra, NJ
    Eibachs aren't bad. They are a little bit softer than anything rated for more improved performance (such as Swift springs or RCE springs)...but as with any spring that lowers further than stock; you are going to shorten the life of the stock struts that are made to handle stock ride height. They may work for a while, but they will eventually wear out shorter than they would if you remained on stock springs.
    Feb 2014
    NJ
    Are the aftermarket struts shocks exp? Right now I'm just going for looks mikie
    Dec 2013
    I think with stock wheels there will not be any issues for lowering because the stock wheels can go inside without hitting with the fenders specially rear ones.
    Dec 2013
    I will try to get something from ebay I know shipping rate will be very high comparing to the springs value but if here it is not available I have no other options but first I should confirm witch springs brand/type will be fine because I can not replace the whole suspension to avoid any possible problems with the
    subaru dealer due to the unlimited warranty till 2016 and should get a black color springs not to draw their attention to it during the regular service.
    Palmyra, NJ
    Ha color of springs aren't going to be what tips them off to changes...perhaps a noticeable lowered ride height?
    Jun 2013
    Auckland, New Zealand.
    I have a 2003 with lowered springs on standard shocks. No problems at all.
    I'm running 235/45's on 17" rims, no rubbing even on bumpy roads.
    The springs are 'King'. Don't know if that's just an NZ brand or not.
