hit a big ass bump
Results 1 to 13 of 13
This is a discussion on hit a big ass bump within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; hey guys i need some more help or a slap across the head cuz I'm a ***** about my car ...
    Nov 2012
    CT
    hit a big ass bump
    hey guys
    i have a 2013 wrx with winter tires and sparco rtt524 rims i was driving and hit a bad pot hole. it ****en broke my front right rim but it's holding air. is there anything else i should check? and i have no idea what i'm doing with suspension so please be as detailed as possible thanks.
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Get your alignment checked/fixed. They should be able to notice any bent pieces, perhaps nothing is bent but the alignment could be off.
    Nov 2012
    CT
    ok thanks
    would it be ok if i still drove?
    Jul 2012
    Rocky Top
    Just ask them to check everything out. You will likely want to get your alignment checked anyway if it was enough to break the wheel! Just tell them what happened and to check out all the suspension, make any necessary alignment corrections, and also put the car in drive on the lift to make sure you didn't bend any other wheels.
    I'd put the stock wheels back on for the drive to the shop, just to be safe.
    Nov 2012
    CT
    the stock wheel has summer times on…….
    Jul 2012
    Rocky Top
    Then I guess you'll have to decide which is safer based on your current weather, the route, and the actual damage to the wheel...etc
    Registered User Chief_WRX's Avatar
    Oct 2013
    Colorado Springs, Colorado
    Like Wreckingball said. Assess the situation. Me personally I would put the stocks back on even with summers to drive to the shop. Have them look at the wheel and check the suspension/ alignment. If everything is okay have them put the winter back on
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    Palmyra, NJ
    I've done that before...
    Nov 2012
    CT
    So what happen to the car any damage other than messed up rim?
    Palmyra, NJ
    Quote Originally Posted by jling0311 View Post
    Had to file an insurance claim to have $3000 worth of suspension parts replaced, including bent control arms, trailing links, exhaust midpipe, etc. That was worst case scenario though.
    Nov 2012
    jling0311,
    Did you get that on the BQE? I heard on the radio that alot of cars had to pull over with flat tires because of the potholes?
    I would check the suspesion on that side, compare it to the other side. If any thing looks bent, then you would need an alignment for sure.
    I would not put the summer tires on unless you want to crash, with all this snow, ice showers, and black ice tonight. I would order a replacement rim and remount the tire unless it has a bubble.
    Dec 2013
    suspension, wheel bearing and hub assembly, axles and of course, wheel alignment and balance.
    Nov 2012
    CT
    Close I got it on the belt. I'm driving her now. The rims holding air and when I let go of the steering wheel it still drives straight
