What would you guys do?
Results 1 to 15 of 30
This is a discussion on What would you guys do? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I'm starting to search for my suspension plus wheels and tires for this spring. I have around 1500-1800 for wheels ...
    Nov 2013
    I'm starting to search for my suspension plus wheels and tires for this spring. I have around 1500-1800 for wheels and tires. Do you guys suggest buying more expensive "stronger" wheels and mediocre tires or cheaper wheels with the best summers I can find?
    Do you have a 13? Doesn't it already come with nice wheels and quite competent summers?
    Nov 2013
    I put snow tires on my oems. Ill probably sell the summers that came on it . Or put them on my gf car.
    I'm looking to put 18s on for the summer
    Jul 2012
    Rocky Top
    What do you want out of it? And what problem is this solving?
    ...with the open ended question I would say get some RPF1's, they're my favorite. (17" diameter). Plus the best summers you can get, because I would be using it at autocross or a track day.
    Rays or Volks can cost that entire budget...used, if not more. So the more expensive "stronger wheels" might be out of your budget if you want tires as well.
    Nov 2013
    I just dd my car. But like the sticky feeling around corners that a good summer will give. I really want the rpf1 18x9.5 sbc but I can't find them in 5x100 anywhere.
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Good call on putting winters on your stockers...I did the same thing
    It is hard to suggest a specific wheel, but nice brands include enkei, some rotas are really nice for your price range.
    I would highly recommend the michelin pilot super sport tires for an awesome summer tire. I have them (as do other members on here), and they are absolutely amazing. They are OEM on a lot of porches and ferrari's for good reason.
    I might recommend you think of staying 17 inch wheels as they are lighter, and also the wheels/tires are less expensive. You could still get a meaty looking set up going 17x9, with a 255/40/17.
    Nov 2013
    Yea ill have to look at some other hatches with 17x9 with big meats. I would still need the rear rolled if I went 17x9 with meaty tires and a 1" drop right?
    Nov 2013
    My options right now are the rpf1 18x9.5 or 17x9 or the xxr 530 in 18x8.75 in chromium black.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    I'd leave it alone until spring. Then get a CHEAP set of rims, put the winters on those, get some good summers on the original rims. Save money and get a Tactrix, DP, tune etc...
    Nov 2013
    Na I'm keeping my motor stock, I like knowing I have a warranty.
    Mar 2012
    That's fine, then get a Bluetooth adapter and the Torque App - actually you can afford that out of pocket money. Give you the ability to read CELS out reset CELs, set up different gauges and monitor things like turbo press, temps, fuel flow etc... And how about sway bars and such? Improve handling, not that it's bad, but it can be made better.
    Nov 2013
    Yea I have eibach front and rear sways already installed. That improved handling so much. That stock body roll is ridiculous.
    Palmyra, NJ
    Quote Originally Posted by 13WrXx View Post
    No contest...XXRs are garbage compared to RPF1s.
    What do you want out of the car? That should determine what you want. I wouldn't skimp on tires because they are what put your $25k car to the road. They play the biggest factor in accelerating, stopping, and handling.
    Nov 2013
    Yea true . Maybe ill just have to up my budget .
    Registered User i8buffalowings's Avatar
    Sep 2013
    Louisiana
    check dezod.com for the sbc rpf1s. you may have to call them but they seem to have them in stock often.
