Front end pop?
Results 1 to 12 of 12
This is a discussion on Front end pop? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hey guys, I have had a pop noise several times this winter. The noise only happens when it is very ...
    Registered User spotsywrx's Avatar
    Aug 2013
    spotsy/farmville va
    Front end pop?
    Hey guys,
    I have had a pop noise several times this winter. The noise only happens when it is very cold and in reverse at full lock. It sounds like it is coming from a joint up front. I have not lifted the car and shaken it down yet. Does anyone know what this could be or have had this problem?
    Thanks!
    2011 Wrx Limited Sedan Silver. Nameless muffler delete, Kartboy Short throw w/ cobb knob, Rally Armor mud flaps, 30% tint... Goodbye warranty Cobb AP v3 and Sf intake. Stink-eye mob #1993
    Whenever I've had a pop noise at full lock it's been an axle. However yours are practically new. Check the boots for integrity.
    Aug 2013
    spotsy/farmville va
    I will when it stops snowing. I was thinking it could have been an axle but then I thought if it was an axle it would be doing it while moving as well?
    Aug 2012
    Tucson, AZ
    Full lock?
    Possible it's pad shift
    Aug 2013
    spotsy/farmville va
    I don't think so? Its pretty loud and you feel it. It only does it one time though.
    Aug 2012
    Tucson, AZ
    Ya you wouldn't feel pads
    What's full lock mean? Is that when you turn your steering wheel all the way? If you don't mind me asking
    Aug 2013
    spotsy/farmville va
    Ya, it happens whenever it is turned all the way to the right.
    Nov 2013
    Do you have aftermarket sways?
    Aug 2013
    spotsy/farmville va
    no, should have added that. Suspension is stock with 54k
    Registered User wrx-V's Avatar
    Dec 2012
    Fort Lauderdale, FL
    I've got the same problem. Also stock suspension with 7k miles
    '02 Sentra SE-R Spec V SOLD
    '13 SWP WRX 4-door
    -Invidia turboback, Grimmspeed EBCS,-TP Stage 2-
    2013 Subaru Impreza WRX
    Registered User atranz's Avatar
    Aug 2012
    houston, tx
    I have the same problem. Sounds like the spring is rotating against the top hat. Only happens from lock to lock. Mines under warranty still. I have to take it in.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Aug 2013
    spotsy/farmville va
    Mine is too, may take it in this weekend!
