02 WRX Struts rubbing on the wheel
Results 1 to 4 of 4
This is a discussion on 02 WRX Struts rubbing on the wheel within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I have an 02 WRX that the previous owner lowered. with the stock rims the bottom end of the strut ...
    Registered User Yobfriend's Avatar
    Oct 2013
    Colorado plains
    I have an 02 WRX that the previous owner lowered. with the stock rims the bottom end of the strut hits the inside tire sidewall when I take a big bump. what are ways to get rid of this problem? would more offset rims to the job or do I need to replace the suspension? I want the cheapest options considered as well. thank you all!
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    Get a stock spring set and an alignment (probably about a $200 total investment if you get used OEM springs, they are very very very easy to get).
    Once the problem is solved, you can address handling issues based on your own driving skills and preferences. Youu may be very satisfied with the stock springs if you add swaybars. The body roll issues in the 2002-2003 (I own one myself and it is my only Subaru) are not cured with springs. That problem is addressed with sway bars. I am mentioning this because I don't want you to feel like I am suggesting a downgrade or reducing the performance capability of your car.
    Is the rubbing only on one side?
    Have you had the car in to a shop to see what specifically is wrong?
    what size wheels, also brand, and what tire size and brand... with those numbers I can tell you if the wheel sizing is causing any issues. Beyond that point, I may or may not suggest tires, THEN the springs.
    Unless they are damaged, your struts should be OK to use again with the corrected springs.
    If there is any leakage, oil around the seals, etc., let us know.
    There are a few of us here obsessed with suspension who have had every form of problem and/or done every modification under the sun, and are successful. Hopefully we can help you get this problem solved economically and quickly.
    The 2002 WRX is an immensely fun car, and is a great performance sedan.
    Before you buy anything, it is a good idea to answer the above questions, size matters...lol
    Oct 2013
    Colorado plains
    stock tires and rims. as of right now handling is on the back burner and the struts seem to be ok. It is on both sides. I just don't want a 2 wheel blowout because of this. will pull the tires to confirm the struts are in good shape later today. thanks again!
    Oct 2013
    Colorado plains
    turns out it is on one wheel only and both struts are intact. what I'm confused about is the strut should not even touch the tire even at full depression. and it doesn't. I swapped tires to see if it has the same effect.
