WRX top hats
Results 1 to 6 of 6
This is a discussion on WRX top hats within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Has anyone installed COBB sport springs for a 2007 WRX TR? the front ones went in fine but the rear ...
    Sep 2013
    Everett, WA
    WRX top hats
    Has anyone installed COBB sport springs for a 2007 WRX TR? the front ones went in fine but the rear is giving me problems. the spring doesn't sit into the top perch at all. i emailed COBB with pics and they told me i didn't have the stock top hats. my entire suspension set up is stock except for the front springs which are now COBB. does the TR trim just not come with top hats for the rear? I know that the TR trim was for people to just get rid of a lot of parts and upgrade to performance, but did they not put top hats on the rear just for this reason?
    Palmyra, NJ
    Top hats are an essential part of the suspension...the TR suspension is the same as any other WRX of that year. So if you don't have top hats, previous owner took them out and never put them back in. I'm guessing he had coilovers and swapped the stock suspension back on, but forgot the top hats.
    Have any pics of the rear assembly???
    Your message implies you have top hats, but not the stock top hats. Please provide a pic of which top hats you do have.
    Sep 2013
    Everett, WA
    yea I see how it sounds. To be more clear, I do have top hats but they aren't the big rubber ones like the front that have a little rubber cover for the strut nut. Mine seem to be just all metal. I'm not sure if this is stock for the year or what. I know the '02 WRX has the big rubber rear top hats. ill post pics tomorrow since I'm on duty(navy) and i cant upload anything from government computers.
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    It definitely sounds like the previous owner installed either adjustable rear tophats, or just solid-mount alloy ones intended for coilovers as stated below.
    I recommend Grouppe-N tophats (Also a Subaru product, readily available online or through your local dealer). They are uprated (can handle more stress) and a good bit beefier than the ones that were originally on your car. Yes, they do make the ride a hair harsher, but for the sake of a stronger connection between the strut and body. This is a good thing, and worth the extra stiffness.
    Sep 2013
    Everett, WA
ID:	127370Click image for larger version.
ID:	127378Click image for larger version.
ID:	127386Click image for larger version.
ID:	127394Click image for larger version.
ID:	127402Click image for larger version.
ID:	127410Click image for larger version.
    sorry for the late pics guys. just got home. im thinking they are the solid mount alloy ones.
