sway bar or spring first? - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
This is a discussion on sway bar or spring first? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Hogdweeb Did the math... for just the yellows and the springs im looking 00. Not sure where ...
  1. #31
    Quote Originally Posted by Hogdweeb
    Did the math... for just the yellows and the springs im looking $4700.
    Not sure where you're getting that # from, but that is WAY too high.
    Konis: $700-800
    Spec-R: $350
    Com-C mounts (F): $200
    OE mounts (R): $100-150 (Group-N: $250)
    The camber bolts and alignment aren't factored into this, as I would recommend them with stock setup...
    Resident Tuner @ WTF Tuning
  3. #32
    Registered User Hogdweeb's Avatar
    Sep 2013
    North Egremont, Massachusetts, United States
    so the 700-800 is for all four corners... thought that all seemed high.
    Where do you primarily get your stuff from? Big thing for me is customer service if needed, and reliability I'll get the right stuff in a timely manner. I'm gonna shop around, do more research, find what I think will be best for me... but I have a better starting point then I did before.
  4. #33
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Tic
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  6. #34
    Sep 2013
    Tic
    Tic stands for? I did a google search and it gave me everything but automotive
    Sent from my DROID RAZR using Tapatalk
  7. #35
    Palmyra, NJ
    TurnInConcepts.
  8. #36
    Sep 2013
    Thanks mikie
  9. #37
    Palmyra, NJ
    No prob man. Give them a call...they're customer service is legendary. They just like things done right, so if you need something specific and they can't provide it or their option isn't better, they will even refer you somewhere that can help. Unheard of.
  10. #38
    Sep 2013
    That's the customer service more companies need to invest in
  11. #39
    Sep 2013
    Com-C mounts... what are they, what do they do, can i substitute them for a set of tophats up front?
  12. #40
    Sep 2013
  13. #41
    Why not go through TiC for everything?
    I am not a fan of Whiteline endlinks; I like the Kartboy versions:
    Kartboy WRX Sedan endlink combo - Suspension
    Sways:
    Sway bar - 24mm X heavy duty blade adjustable MOTORSPORT - Suspension
    Sway bar - 22mm heavy duty blade adjustable - Suspension
    Com-Cs:
    Camber/caster correction - strut mount offset assembly - Suspension
    They used to sell the Spec-R springs (I'm not seeing them on their site quick), so ask them about them, as well. If you pair everything together, you may be able to get them to give you a bit of a break. Not sure, but often times, vendors will give a bit of a discount on larger orders.
  14. #42
    Sep 2013
    I was combing through TIC and only saw the struts and top hats. Didnt see my springs, and at first the whiteline bars. I'll go through and add the bars from TIC though vs. RSD. The Com-C not being referred to as a "Com-C" on TIC threw me off there. I was going with the Whiteline end links because I've always had this little OCD thing almost about matching manfuacturer parts to manufacturer parts if I can. I've also heard some shifty things about Kartboy... and just as many good, so I was on the fence about Kartboy. When I get the money together I'll call and see if they still have the Spec-R springs. if not, I'll have to go through a seperate supplier, but not the end of the world. Didnt know about the possibility of discounts for large orders..then again I've never made 1k+ purchase at a given time from a single supplier. its always been when money permits for something. Thanks Matt!
  15. #43
    Jul 2012
    Rocky Top
    That escalated quickly..
    Killer setup though!
  16. #44
    Sep 2013
    It did escalate quickly... But having more input then i was expecting helped. If only i had the money right now...
