Clinking noise
Results 1 to 8 of 8
This is a discussion on Clinking noise within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I've search all over the web. 1. Abs noise 2. Power steering noise I can't rule out the power noise, ...
    Registered User atranz's Avatar
    Aug 2012
    houston, tx
    Clinking noise
    1. Abs noise
    I can't rule out the power noise, but I know its not the abs noise. After I got an alignment my 2013 sti (at the dealer) started to make a metal to metal clinking noise when I turn the steering wheel from lock to lock. It's louder when I'm reversing . Before I take it to the dealer I wana know if other have the same issue. Plus the dealership is 40 miles from me.
    I jack up the car and turned the wheel and it sounds like a spring popping or the top hat making the noise. I loosened the 3 12mm nuts holding the strut on and the noise went away. I tightened it and the noise come back.
    Opionions needed thanks
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Palmyra, NJ
    Take it to the dealer...its worth the 40 miles to not have to pay for anything. It's under warranty.
    Aug 2012
    houston, tx
    I have one more theory/fix before I take it in. It could the the saybar bushing. Ill put some grease on it. If it does not fix the problem I'll take it to the stealership.
    I do not like the dealership. I feel I can do a better job fixing it myself, but it's warrenty work.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by atranz View Post
    Your car comes with a warranty for exactly this reason. Don't risk a denied claim by messing with it yourself.
    2007 Outback 3.0R wagon
    Palmyra, NJ
    Are they aftermarket sway bars?
    Aug 2012
    houston, tx
    No, they are stock.
    Palmyra, NJ
    Interesting...never heard stock sway bars make noise.
    It's almost impossible to diagnose a noise over a visual medium...so post a video of what you're hearing so we can listen. Otherwise, I think you're going to be SOL trying to get an answer here.
    Aug 2012
    houston, tx
    Thanks for the input guys. If the grease does not fix the problem. Ill abuse the warranty.
