Need advice on a caliper and rotor upgrade for my 12'
Results 1 to 5 of 5
This is a discussion on Need advice on a caliper and rotor upgrade for my 12' within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I am sorry if this question has been asked a million times, but I am new to the site and ...
    Jan 2013
    Fair Oaks CA
    I am sorry if this question has been asked a million times, but I am new to the site and new to WRXs. I have a 12' hatchback base model and would like to upgrade the brakes to an "STI" standard. I realize that my 5x100 bolt pattern would prohibit a straight swap from an 11'-13' STI. However, I have been told that 04'-13' STI fronts will work while 04'-07' rears will need a bracket. 08' rears are a direct bolt on. Is any of this correct, or am I totally off? From what I have seen, a new Brembo package on all four wheels would be very expensive somewhere around $5K. Any info on this would be very helpful. Thanks in advance.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Fronts will bolt to the knuckle. Adaptors are available for the rears. I'd suggest performing rotors/pads/fluids and SS brake lines first. If you aren't happy, then consider the calipers.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    Honestly, I would look at it as a good opportunity to upgrade hubs and bearings at the same time. There are a lot more (better) wheel options for 5x114, and the wheel bearings that go with the 5x114 hubs are a good deal better.. or at least they were on the older year models.
    Registered User W_R_XTC's Avatar
    May 2012
    brunswick ohio
    I did a caliper swap from an '06 TR onto my 2012 wrx. direct bolt up, no need for rotor replacement, and gives you 4 piston front and 2 piston rear. I know they are no sti brembos by any means, but still a noticeable gain.
    Registered User JimboWRX's Avatar
    May 2013
    NY
    You can put on the 2004+ STI Front and 08+ STI Rear Brembos on a 2011+ WRX with virtually no modifications. They bolt right up to the existing knuckles (no brackets required). You will also need a set of front and rear STI rotors drilled for the 5X100 pattern. KNS Brakes sells dual drilled pattern STI rotors.
    Okay, so there's one small modification: To allow the rear rotor to clear the dust shield, the dust shield can either be trimmed or removed. This is the only real modification required to make the upgrade.
