Tire Pressure
Results 1 to 15 of 20
This is a discussion on Tire Pressure within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hey guys, I have a little question about my tire pressure. My tire pressure light came on so I went ...
    Registered User blee5192's Avatar
    Aug 2013
    Bay Area
    Tire Pressure
    Hey guys,
    I have a little question about my tire pressure. My tire pressure light came on so I went to go fill up my tires to 33 PSI front and 32 PSI rear as said in the owners manual. I checked my pressure and it seems okay but the light did not go away until after I left my car sitting for a couple of hours.
    My question is...is this normal for tire pressure light to disable after the tires settle in?
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Yes this is normal if you don't drive the car after. If you drive the car after it will usually go away within a couple of minutes.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Those sensors don't transmit all the time, only when wheels are turning at some minimum speed and then only every so often.
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    Hey blee. Its getting cold man. Tires drop pressure when it gets cold. 'Specialy low profile tires with very little interior volume. I don't know what the max pressure is on your shoes but this time of the year I'd recommend two to three extra psi on top of recommended Unless its over max. You should be fine tho. That should give you some headroom for temp drop to keep the sensors happy and not enough over the manual to really affect the driveability or ride. That, or your going to be adjusting your air pressures a lot over the winter. Like me. hahha!
    when my friends come up, i hear, "you sold the camarrrroooh.....HOLY BLEEP A WRX!"
    Ya has that effect on me too.
    Rob
    Where did he go?? http://www.clubwrx.net/forums/builds...ll-thread.html
    Aug 2013
    Bay Area
    Quote Originally Posted by tirerob View Post
    Thanks rob! It was weird cause I know sensors go away in a few minutes but I went to the grocery store then drove around a little and it was still there. Now it's fine. It's gone! I just kept second guess myself because it looked little low but maybe I was just tripping over the fact that the light was on. Haha
    Nov 2012
    Lol, don't get me wrong. The sensors are usually very accurate. They also have a smaller tolerance for pressure too low/high(which at a certain pressure will trip the light as well.) Because of the low profile tire, a small leak will cause a run flat and ruined tire waaay faster that say a half ton pickup tire(nearly equal tire pressure. Just way more volume in a pickup tire) so...the sensors are working just fine. And just like 11 black and ingo said. When the tire reaches a operating temp and the pressure climbs, the sensor reports all good. Were just moving the operating range of tire pressure up a bit. Enough to satisfy the sensors, your driving style, and the wear/safety of your tires. Consider how much a set of four is for you, or any of us any more and getting ocd with tires really isn't a bad thing lol
    Rob
    Aug 2013
    Bay Area
    What are the PSI of different driving styles and what are the PSI for better MPG? haha
    I also heard that if you get bigger rims the PSI goes up?
    Jul 2012
    Rocky Top
    The optimum PSI for certain conditions would depend on the wheel specs and the tire specs and temperature and the track and the driver etc.
    If you have stock wheels and tires then the optimum psi for handling and MPG would probably be what's on the door. I wouldn't know though lol.
    Aug 2013
    Bay Area
    damn my tire pressure light came on AGAIN! idk if theres a hole or not! i hope not! i gotta check tomorrow! sighhhhh!!!!!!
    Nov 2012
    OK...that sux. If that's the case. Yes, IMO you most likely have a tire going flat. Something is causing the sensors to trip and I've found them to be annoying, but accurate for the most part. So before a tire is all the way flat(if you can't see one already) grab a air gauge and checkem. Find a or the lowest and hit up a tire shop. I'd stay away from any that do external repairs. They don't last and begin to leak soon after installation. Plus...they can't see if your tire is damaged inside. That said...a quick plug that you put in might save you from buying a new tire/s but I digress.
    If you do find a low tire and want to check...we use a healthy dose of dawn dishwasher soap in a big squirt bottle. Mix it till the water turns dark green-blue and go to town on the tire. Find something bubbling and bingo. Off to the shop. As a add...if you find a leak and decide to change it yourself to the spare, at our shop walk-in repairs get punched out quicker because not being on the car. Specialy if they're already marked where the leak is lol.
    Rob
    Aug 2013
    Bay Area
    I found a small nail in the inside part of my rear left tire. Sigh!!! Should I just get a patch? Or is there something else I can do to save my new summer tires!!!? =[[[
    Nov 2012
    Haha noooo its not that bad I don't think. Take it to a professional tire shop and have it repaired. Once that's done your good until you get 'nailed' again. Just get it fixed asap to prevent damage to the inside from running low. Nails are almost generally reparable.
    Rob
    Aug 2013
    Bay Area
    I went to a BIG O tire and got it patched for $22. Not bad.. When the dude backed out my car .... he totally just stalled it haha... all the workers were laughing at him lol
    Nov 2012
    Haha worth every buck for a good laugh. At least he didn't dump and launch. That's cool
    Rob
    Aug 2013
    Bay Area
    ohhh hell no! if they did i would be mad and demand a free patch! haha. im anal about people driving my car that i dont trust like tint store, tire places, etc. You on chat right now?
