guesses on this wheel/tire size? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
This is a discussion on guesses on this wheel/tire size? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I'm surprised you would need spacers with that offset....
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Registered User Lukhard's Avatar
    Aug 2013
    I was surprised too. In this thread on NASIOC (Enkei 17x9 +45 rpf1 & bbk - NASIOC) gusto says that he needed them on his 2006 wrx wagon.
    So the $400 difference between the SBC and silver... anyone think it's worth it??
    Nov 2012
    Quote Originally Posted by Lukhard View Post
    What is SBC?
    I have 45+ offset on my car and I have brembo brakes...
    Edit - ah looking at those wheels it appears they are set in...for the deep dish look. Makes sense. Glad I don't need spacers.
  6. #19
    Aug 2013
    it stands for "special brilliant coating". the wheels on the car I posted in the first post on this thread are SBC. trying to figure out if it's worth the extra $100 a wheel.
    ... and those wheels are +45 as well. I don't understand hey he needed spacers but you don't need them on an STi with the exact same wheel.
  7. #20
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Why not run the proper offset instead of getting spacers? Just seems more logical to me.
  8. #21
    Aug 2013
    Quote Originally Posted by A265 View Post
    Of course... As I stated, I would be getting as close to the stock offset as is offered in that wheel, +45.
  9. #22
    Mar 2009
    in a igloo
    I'm not a expert, but since you are going with a much wider wheel then stock the stock offset won't work (proved by needing spacers). Why not get a +48 (if available) as that's what spacers basically do, add positive offset to the wheel.
  10. #23
    Nov 2012
    I think what he is saying is that +45 is the max offset he can get for that style. The reduction in offset from stock would be partially offset by the wider wheel as far as suspension geometry. I am just surprised that the reduction in offset would require spacers, but that is partially dependent on the design of the wheel itself. I actually have much more room to clear my bremos with a +45 offset wheel than my stock offset, due to the shape of the spokes on the wheel. Looking at the design of the wheels that are being discussed here, the design appears that the spokes are straight with no outward curvature, which is probably what is causing the issue.
  11. #24
    Aug 2013
    Yes, the max offset for the 17x9 5x100 RPF1 is +45. I've been told by someone who put these wheels on his 2006 WRX wagon that I'll need at least 3mm spacers up front. My dilemma at this point is deciding whether the SBC coating is worth the $400 extra. The car that I posted in the first post of this thread has SBC wheels, here's what they look like in regular silver
  12. #25
    Jul 2012
    Rocky Top
    Yes, the design of the wheels are notorious for not fitting under "larger" brakes. They almost always need spacers. Due to the design of the wheel, simply adding offset won't do much or anything for clearance. I would assume by looking at my wheels, to make these fit under large brakes, you would actually have to subtract offset and move the spokes farther away from the car.
