Now have SS lines and ST pads, but pedal still has a lot of play...
Results 1 to 10 of 10
This is a discussion on Now have SS lines and ST pads, but pedal still has a lot of play... within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Do I need to get the master cylinder brace? For those who have them, does it make a big difference ...
    Jan 2009
    Md
    Do I need to get the master cylinder brace? For those who have them, does it make a big difference with pads and lines? I have Valvoline brake fluid and all of the lines have been bled.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    Apr 2004
    Southeastern PA
    ST?
    Mods & Pics
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by Sasquatch View Post
    ST?
    Stop tech
    Nov 2012
    Have you brought it out for a ride yet? When I changed my lines it took a few good pumps of the brakes before I noticed the pedal feeling stiffer. The brake pads won't have any impact on the pedal feel so if you are looking for a stiffer pedal you probably want to look into the master cylinder brace. Interesting that you didn't notice a fair difference because when I did mine (Goodrich ss lines and Super blue fluid) I noticed a pretty good change. How did you bleed the fluid...pumping it out with your pedal or with an actual bleeder?
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    I had a shop swap on SS lines and ATE Superblue into the bugeye, and the difference was very noticeable the moment I drove away. As suggested, I'd recheck the line bleeding again and see if any extra bubbles in the lines.
    2007 Outback 3.0R wagon
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Sounds like a bad bleed to me. Was there any improvement to the pedal feel at all?
    Jan 2009
    Md
    No, I did the old pedal and cracking the bleeder method.
    Jan 2009
    Md
    I mean it's not like OMG this is HORRBILE type bad, but you have to push a fair amount, I mean they won't just bite right away unless the pedal is down a fair amount. I know a lot of people use the ATE fluid, but TBH fluid doesn't cause the pedal to be stiffer somehow does it? I mean does it somehow have more compression than just regular Valvoline fluid?
    Jan 2009
    Md
    Quote Originally Posted by mcdbrendan View Post
    Yes, there was a little bit better feel. When I had gotten my lines and bled the brakes, it helped a little, but I was less than impressed.
    Jan 2009
    Md
    I wanted to come back to this thread because i'm just been thinking about it for a while. I don't recall the order in which I bled the brakes, but I found it on here ... several times so i'm pretty sure it was correct I just pumped the pedal about 10 times, my brother in law cracked the bleeder, he looked for bubbles and after all of them were out I did it one more time just to make sure, before moving to the next side. I also made sure to fill it up at any time that it started to get low and then after I was done, it was filled to the max line.
    Does it sound like something got screwed up in the process maybe?
