Let's talk tires
Page 1 of 3 123 LastLast
Results 1 to 15 of 34
This is a discussion on Let's talk tires within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So many times I see people asking about handling on their WRX and how to make it better. Many times ...
    Jan 2009
    Md
    Let's talk tires
    So many times I see people asking about handling on their WRX and how to make it better. Many times I see the response that "you should get tires first". I'm not disputing this answer. However, ask I have come from 2 Evo's I've had the very sticky advan 140 series tires. I HATED them. They were like taking pieces of chewed gum and making them really hot so they could throw rocks all over your car. I later on had to change tires and got the conti dws. of course I could immediately feel the tire roll a lot more BUT the car would still hold corners quite well considering they are a 520 series iirc.
    At the time I had my X, many were going with the ventus v-12's which are (like our stock tires) a 280 series. Some went with the star specs if they did some track days or wanted a good tire that seemed to last a bit longer than the advans.
    I'm a fan of being a better driver and using what you have to the best of your ability. That being said, we all I think understand that eventually physics takes over and some things simply must be done to make the car handle better.
    Now I do understand, as with anything that numbers do not tell the whole story of what a tire can do vs another one.
    So... I wanted to get people to chime in on what tires they believe are better than the OE's, but aren't sticky to the point where every little stone gets thrown onto our already cheap ass paint.
    Your choice after your stockers went our were... what?, why? and how did you like them?
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    Cooper RS3-S's seem to be the general consensus on the forum right now.
    I personally have the Cooper RS3-A's because I had to get tires in the winter and didn't have enough to get two sets. I love them. I can't speak for the S's but if the grip on my A's is any indication I'm sure they're awesome.
    The price was right, they are non-directional so I can rotate them properly and they have a pretty good tread life.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Jul 2013
    Silicon Valley
    When you say "140 series" "520" "280" are you referring to treadwear? While the treadwear rating vary more-or-less directly with the traction of the tire, using these numbers to judge the quality of the tire will give you only an idea as to their normal longevity and little more. You need to look at the traction and temperature ratings primarily for a vehicle such as the WRX. When considering high performance tires, treadwear is likely the last thing on your mind. Much in the same way, when considering an AWD turbo vehicle (or any sports car, really) fuel consumption ratings are not really your (my) concern.
    Regarding the WRX, I've only used the Dunlop OE tires. It's my daily driver but I like to press it on tight winding roads and hard turns. The grip seems decent but given the price range of the tire, I feel as though the sidewall is too soft. And a single "A" rating for $200/tire is piss-poor, in my mind. This is being said, however, with just barely 500 miles on the car and, therefore, nowhere near top throttle. Having said they are decent though, I prefer a grippier tire and stiffer side walls. For less money, at that.
    The next tire will likely be a Bridgestone Pole Position--I've enjoyed every PP I've owned. Depending on price, a Pirelli is a possibility too although I've historically noticed more road noise with them.
    Apr 2004
    Southeastern PA
    Michelin Pilot Super Sport. The best tire I've had on the WRX in 9+ years. Treadwear # is 300. The treadwear number is only comparable within a given manufacturers range of tires. A 300 from Bridgestone is not the same as a 300 from Michelin.
    Mods & Pics
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by Sasquatch View Post
    I second these. I love the MPSS. Hands down best tire I've ridden on any car. Ever. I will definitely be buying them again. Great grip, smooth ride.
    Registered User tesla317's Avatar
    Aug 2012
    I third these. If you are staying in the summer tire category, then these seem to out perform all others and are considerably cheaper than most. Best bang for your buck, best tread life, and they are so so much quieter than the dunlops that my 2010 wrx came with. Night and day difference!
    I ordered these through Wal-Mart's website, all four were $813.00 free shipping. Considering they beat the Dunlops in every way, and much cheaper...how can u afford to not get these?
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Quote Originally Posted by tesla317 View Post
    In for number 4, the PSS is hands down the best tire I've ever had. I'm just north of 1k miles on mine and while they are a little sticky (can hear plenty of gravel/rocks after bringing them to heat), the performance is completely worth it.
    EDIT: I should note I just got mine 3 weeks ago from Tirerack for $770 shipped.
    Jan 2009
    Md
    Quote Originally Posted by Zataks View Post
    I understand the series of the tire doesn't tell the whole story... that wasn't really what I meant, but is sort of a loose gauge of how hard or soft the tire is so you can figure you will get better grip from a 280 vs say the 520 I had mentioned.
    So no one has tried the Ventus v-12's on these cars?
    Dec 2011
    Boulder, CO
    Quote Originally Posted by Methodical4u View Post
    Looks like there's plenty of feedback on the V12s. Google results
            MainFrame's Avatar
    Austin, TX
    Hundreds (if not thousands) of people have..
    For what it's worth, Matty was running v12s until one of them failed catastrophically while exiting the highway. He now has Cooper RS3-S installed and seems to prefer them over the v12s.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Let's talk winter real quick. I've been advised not to deal with the all weather tires since I live In NH. But go for a second set of strictly snow. Recommendations ???? I've done some homework blizzards, Altimax, Nokian , the latter I've heard are awesome ($$$$),opinons ???? Also looking at 16 inch steelies for mounting.
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
    Nov 2012
    Quote Originally Posted by cogito View Post
    I haven't ridden Nokians, but from what I hear they are the best. I am going to get those for my next winter set. I currently use Blizzaks and for the money I was happy, but not in love with them.
    Jan 2009
    Md
    Well I asked because I have a friend who can get them very cheap locally and so when it comes time to change tires (assuming I still have the car) I wouldn't mind getting them since the price is better IF they are considered a good tire for this particular car.
            MainFrame's Avatar
    Austin, TX
    They're decent.. most complaints are about the soft sidewalls. I would be concerned about quality control issues, with the tread separating from the tire. Not a risk I was willing to take, so I decided on the Coopers, they're pretty inexpensive for a performance tire.
    Jan 2009
    Md
    I'll have to find out about those from my local guy and see if those are on his list.
