Suspension under $1000
Page 1 of 3 123 LastLast
Results 1 to 15 of 45
This is a discussion on Suspension under 00 within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hello everyone thank you for reading and posting your thoughts in this thread. I own a 2003 WRX, and I ...
    Registered User MrSubielove's Avatar
    Aug 2010
    I own a 2003 WRX, and I think my suspension needs attention, It might not be long until my car rides like a boat. So here I am looking to seek an advice from all parts of the world.
    I don't have much to spend on suspension work, Might do it myself, I only have $1000 budget for a set of 4. I'm gearing toward adjustable coilovers but (Obviously my price range would land me in a bad quality) it looks like an impossible thought for the price I want.
    Do you have anything to suggest on whats a good name out there, should I go for coilovers, or should I go for struts and springs for my Budget PRICE?
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Do you track your car? If not, go struts/springs. Koni is a good name.
    Struts/springs
    With a car that age, you're going to want to replace the entire assembly. With a $1000 budget, I'd say do the following:
    KYB GR-2 struts
    Swift Sport springs
    New OE mounts (F/R)
    Camber bolts (rear)
    Alignment (custom spec, not OE) - max out the front bolts as much negative as you can without cross-camber (-1.2-1.5°), dial back the rear to -.8-1.0° (I like ~.5° less in the rear vs the front), and zero toe all around
    That will freshen up the struts (which are likely pretty worn on a 10+ year old car), give you a little better stance, a bit of a handling upgrade, while staying within your budget.
    Ride quality, looks, handling...all improved. Where the $1000 coilovers you were considering, wouldn't do all that.
    Resident Tuner @ WTF Tuning
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Here's my $1000 suspension recommendation.
    • Cheap softish set of springs (STI take offs will work) $50-$300
    • kyb gr2 struts $350ish
    • rear camber bolts $50ish
    • whiteline ALK $260
    • custom alignment $100?? Or DIY
    • New front top hats $60
    Optional:
    • whiteline com c front top hats $200
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Aug 2010
    no, I don't track anymore. I just daily drive my car now. I will look into koni brand. thank you
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    $1000 isnt really enough for a good set of adjustable coilovers. unless your planning to track the car just replace the worn out stuff. get a decent set of shocks and springs and throw in some poly bushings while your down there. other than that not really a point unless your going to try to race around some corners on a public road at double the speed limit and kill someone
    2013 wrx sedan(saving up for a 2015 STI)
    Previous faist cars: '05 Mustang GT '02 RSX-S, '91 SR20 240sx, '85 300zx turbo
    Nov 2012
    Quote Originally Posted by MrSubielove View Post
    Also look into what EJ257 and 06wrx4me suggested. They know more about this stuff than I do. I am still on stock suspension on my STi (although I do have way better tires and a customer alignment, which was a dramatic improvement in handling).
    Aug 2010
    Thank you, I will look into this one.
    You mentioned about the struts being freshen up, are you talking about the alignment will cause it, or everything? I'm looking into KYB GR-2 struts. thanks, it will land me under my budget which is a good thing.
    Aug 2010
    I would like to be able to tackle corner. do the KYB GR2 and Swift Sports Springs that EJ257 and 06wrx4me suggested and may be add a sway bar? will that do the trick?
    Aug 2010
    will do.
    Aug 2010
    Struts/springs
    KYB GR-2 struts
    Swift Sport springs
    New OE mounts (F/R)
    Camber bolts (rear)
    BTW, Negative camber, wont that cause my wheels to be angled a little? Should I be concern of uneven ware on the inside of my tires? mmmmmmm
    The tops of the wheels will angle inwards. I've never been concerned. See alignment info in sticky threads; other angles do matter for wear (e.g. toe).
    Registered User Fast Tuning Products's Avatar
    Sep 2012
    West Newton, Pennsylvania, United States
    If you're interested in some pricing send us a PM.
    Available Nights and Weekends Via E-mail and Private Message!!
    We want to Earn your Business!
    Give Us a Call Monday - Friday 10a-6p EST to order by phone!
    724-708-3044
    Need a price matched or beat? Email Us: sales@fasttuningproducts.com
    Like Us on Facebook: www.FaceBook.com/FastTuningProducts
    www.FastTuningProducts.com
    We Accept Paypal/Visa/MasterCard/American Express/AMEX/Discover
    Jun 2006
    Nor Cal
    FWIW on the sway bars....
    Your car came with 2 sway bars, they are pretty small but work. If you upgraded both bars, end links, and mounts, you could come close to $1000 alone on just that stuff. Since your struts are blown, I say save them for later.
    The Whiteline Anti Lift kit I mentioned for $260 is a definite feelable upgrade.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Palmyra, NJ
    For good handling, negative camber is necessary to create the most contact possible when within the turn. A -1 or -1.5 degree of camber shouldn't wear your tires out too much more than normally, especially if you're good at keeping them rotated properly. Many others here are running -1.5 to -2 degrees just fine.
