Suspension under $1000 - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
This is a discussion on Suspension under 00 within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by EJ257 That uses up 0 of the 00 budget true, but anything worth doing is worth doing ...
  1. #31
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    That uses up $850 of the $1000 budget
    true, but anything worth doing is worth doing right lol. KYBs would work too OP
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  3. #32
    Quote Originally Posted by Sinister
    Koni Yellows / Tokico D-Specs, as well as higher rated springs, are a better choice than what I listed from a ride quality / performance standpoint. Then get into firmer tophats and/or camber plates. Then consider swaybars and endlinks to account for the increased spring rates. Factor in all the worn bushings that are in need of replacement, as well. It's a slippery slope.
    Within the budget constraints, they didn't fit the bill.
    Resident Tuner @ WTF Tuning
  4. #33
    Nov 2006
    Denver Metro Area
    Guys, when did Matt get so serious
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  6. #34
    Palmyra, NJ
    Since Zax and Drews became so jaded at anything Subaru
  7. #35
    Registered User STiDriven's Avatar
    Apr 2004
    St. Louis
    Quote Originally Posted by wreckingball man View Post
    Lol, if the rear isn't adjustable then I must have been dreaming that I went to the alignment shop.
    A good alignment shop can do a little - if they are willing. Yes - there is no 'adjustable' hardware stock. However, you'd be surprised the amount of camber you can get if you have someone (or two) people pushing on the upper part of the wheel while the strut bolts are loose. Then you torque them back down while pushing. You should be able to pick up another -0.5 deg if the shop is willing to do this. That's how much I got.
  8. #36
            MainFrame's Avatar
    Austin, TX
    The OEM hardware IS adjustable. There are two bolts attaching the spindle to the strut. The lower bolt has an oval shaped lobe on it that changes the camber angle when turned. Every alignment shop I have been to (aside from Texas Track Works) in the last 11 years has told me it's not adjustable, until I point that bolt out to them.
    I can probably provide a picture of the bolt if anyone would like.
  9. #37
    Jul 2012
    Rocky Top
    Happened to me many times. All they do is look at the computer and say, "welp, we can't do ****." then I'm like, "look at the car you imbecile." Then they look at the computer again and say, "sorry there's nothing we can do. We sell camber bolts for (ridiculous price here)."
  10. #38
    Nov 2006
    Denver Metro Area
    Mine was installed with 1 eccentric bolt up front and two solid bolts in the rear. So unless my WRX was completely different than every other one....
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  11. #39
            MainFrame's Avatar
    Austin, TX
    Well.. I've only owned 02 WRXs. The first one I bought new. The second one came with coil overs which I replaced with the suspension from my first car (and by that time I already had Eibach crash bolts in the rear).
    I bet there was an undocumented change somewhere along the line and they quit providing adjustable bolts in later years.
  12. #40
    Jul 2012
    Rocky Top
    I quoted mainframe, but after reading I think I should clarify. For me it was not the bolts, but my struts had a lobe shaped hole for the top bolt that allowed a little bit of camber adjustment. Maybe mine were drilled out by the previous owner?
  13. #41
    Registered User MrSubielove's Avatar
    Aug 2010
    OK! lots of conversation going and I've been gone for a long time!
    Does anyone know or have a link for torque specs for all nuts and bots that will be un-installed and re-installed during this upgrade/replacement of my suspension?
  14. #42
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    I would look for a shop manual for your car, it will have all the information you need and then some.
  15. #43
            MainFrame's Avatar
    Austin, TX
    I know there is a list of torque specs on here somewhere.. I used it 10 years ago when doing my suspension.
  16. #44
    Aug 2010
    So, here's an update on my search http://ken-gilbert.com/wrx/mans/5%20-%20CHASSIS.PDF
    under chassis section, page 21 (for those who might be on the same boat as me)
  17. #45
    Aug 2010
    or this one for those maybe needing for their most current WRX/STi
    Factory Service Manuals
