#caliperprobs
Results 1 to 8 of 8
This is a discussion on #caliperprobs within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So I tried to change my pads and rotors the other day and one of the pistons on my right ...
    Registered User Buzz's Avatar
    Feb 2007
    rochester
    #caliperprobs
    So I tried to change my pads and rotors the other day and one of the pistons on my right front caliper wont retract far enough to accept the new thickness of the parts. It appears heavily corroded (boot intact) and I tried even tapping it with a brass drift pin to get it to move back further with no success. I looked in to rebuilding it but idk if the piston needs replacing or not, and I probably don't have the time to take the caliper apart, only to find that it needs to be replaced after all ( I couldn't find a place to order new pistons). I found sets of four pot calipers all over with one set in the 550 dollar range (the cheapest I could find), so im in the market for either refurbished calipers or a single right caliper. Does anyone know a good source of calipers that wont kill my bank account?
    06 TR, COBB AP2,,COBB DP, K&N sr, G200 CB
    Subaru factory short throw, Auto dimm Rear view, Factory fog lamp kit (self installed)
    AM cobalt gauges: WB fuel, oil press (elec), boost (mech,30hg-20+)
    Registered User cmayba's Avatar
    Feb 2013
    Upstate NY
    What method did you use to retract the piston? Corroded or rusted?
    Feb 2007
    rochester
    I used pliers to get them back until they stopped, then tapped the one that wouldnt go back all the way with a brass drift pin. It didn't move.
    Feb 2007
    rochester
    Quote Originally Posted by cmayba View Post
    The pistons are very rusted.
    Feb 2007
    rochester
    OK, So iv'e been looking around and found a place that sells calipers (although not very cheaply), but it says "bare" by the description. What does that mean? Will I need to do any work on it before I install it?
    SubaruParts.com - Your #1 Source for OEM Parts and Accessories
    Feb 2007
    rochester
    I also found these guys, who replace the pistons with stainless steel. Which Idk if the stock ones had stainless pistons or not, but they sure rusted like they didn't.
    Subaru reconditioned 4 pot calipers
    Oct 2011
    Santa Ana, CA
    Quote Originally Posted by Buzz View Post
    I don't think pliers can exert enough force to push a caliper back in. Seems like it might be binding because it's not being pressed in evenly. Use a set of caliper spreaders or a large c clamp.
    Posted from a fone.
    Feb 2007
    rochester
    Quote Originally Posted by UEDan View Post
    Posted from a fone.
    Ill give it a shot, until then I hope to get some links to some caliper and caliper parts websites.
