I just ordered these from TireRack and installed at NTB for around $510. Pretty good deal on the tires ($93 each).
They are the "94Y XL" load range, the higher of the two range choices on the tires (they also had a 91Y version). I typically ran somewhere around 35 psi on previous tires. With the higher load range, should I run higher pressures to get the advantage of stiffer sidewalls? Max pressure is 50psi.
I have them at 35 now and they feel kinda soft, but that probably has a lot to do with them being new, and my old tires were hardened from age.
Its for my '02 WRX Wagon, 17x7.5 wheels.
Thanks!
Thanks!
