Maximum negative camber is a +.3
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
This is a discussion on Maximum negative camber is a +.3 within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So I took my car to get aligned and they said the maximum negative camber they could do was a ...
    Registered User SubaruWRC's Avatar
    May 2007
    New Orleans
    So I took my car to get aligned and they said the maximum negative camber they could do was a +.3! Is this possible? They said they got a -1.2 on the rear so they know what negative camber is... Is there anything that they may be missing?
    Sent from my SCH-I545 using Tapatalk 2
    STU 17
    Hawk-Eye Alliance #117
    WATCH THIS
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    You should be able to go way more than that...at least -1 prob -1.5 since you have a hawkeye
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Do they know what they're doing? If I recall correctly there's some kinda "off-center" nut to adjust camber. And positive is definitively wrong.
    Apr 2004
    Southeastern PA
    Take it to another shop. They clearly do not know what they are talking about.
    A good custom alignment will likely cost more, but is well worth it.
    Mods & Pics
    They may not have unbolted both bolts on the strut "ear" thingies. If you don't do both bolts you are very limited in adjustment. Another possibility is that they are developmentally disabled.
    - Al Stewart
    Palmyra, NJ
    Find a new alignment shop.
    Apr 2004
    Southeastern PA
    You should find a shop that is familiar with custom alignments. Call around, ask lots of questions.
    Camber bolts added to the rear are a nice addition for autox. They add more adjustability in the rear.
    Nice ...
    Mods & Pics
    May 2007
    New Orleans
    So I spent $80 on an alignment should I just try to get them to fix it or eat that money and go someone else
    STU 17
    WATCH THIS
    Apr 2004
    Southeastern PA
    Quote Originally Posted by SubaruWRC View Post
    Ouch. Try to be pleasant and carefully explain what it was you were after. Did you state this clearly up front?
    This is no doubt what happened. I was so amused by the developmentally disabled comment I whizzed right past it. Tell them there are two bolts.
    Mods & Pics
    Palmyra, NJ
    Tell them that they should fix it at least to factory spec. If they can't then they shouldn't be in business and you will certainly post your reviews of your experience. Don't make a negative threat, but let them know that you are unhappy with the service. As far as I'm concerned, that's a major service failure.
    Apr 2004
    Southeastern PA
    Good answer. Try to get them to adjust the front - if that fails ask for factory specs and move on $80 poorer, but wiser for the experience.
    Mods & Pics
    Quote Originally Posted by Sasquatch View Post
    Yoda said it. "Disabled, you are. Developmentally."
    - Al Stewart
    Apr 2004
    Southeastern PA
    Roffles!
    Mods & Pics
    Jan 2012
    Philly Area
    Props for using the current accepted terminology!
    - Will
    May 2007
    New Orleans
    Sasquatch. I told them exactly what I wanted which was maximum negative camber in the front and rear with zero cross camber. And zero toe. Can anyone point me to where I can find a how to on what bolts to undo.
    STU 17
    WATCH THIS
