Maximum negative camber is a +.3 - Page 2
Results 16 to 30 of 35
This is a discussion on Maximum negative camber is a +.3 within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; The "ear" bolts is an excellent description. One is a pivot point, the other is a cam bolt that allows ...
    Apr 2004
    Southeastern PA
    The "ear" bolts is an excellent description. One is a pivot point, the other is a cam bolt that allows for adjustment. I do not remember which of the bolts (upper or lower) pivots or has the cam. Loosen both, see which swings the lower strut inward or outward.
    For what its worth, I have eyeballed the camber manually, then taken the WRX for a precise alignment. My eyeballing was much closer to the negative camber value than I would have imagined.
    Wish I could explain it better ...
    Mods & Pics
    Registered User SubaruWRC's Avatar
    May 2007
    New Orleans
    So I called today with this information and they said there is no possible way they can do any better than +.3. They also said I don't have an eccentric bolt. Does this make sense?
    Sent from my SCH-I545 using Tapatalk 2
    STU 17
    Hawk-Eye Alliance #117
    WATCH THIS
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    I would go somewhere else. These people obviously have no idea what they are talking about. I mean that is not even what the stock spec's are...
  6. #19
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    This!
    Why do you even still have the car there?
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  7. #20
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    The WRX comes stock with a front eccentric bolt, its the top one. Tell them to GTFO newb. Also click on the DIY alignment thread in my sig for pics of the bolts, and a better explanation of the system.
    FWIW you could always DIY to insure it is done right. 3 alignments at that price would have paid for all the tools to DIY.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  8. #21
    May 2007
    New Orleans
    So here is the bolt that was in the top part of the strut. That is not a camber bolt. What do you think happened here? Did someone swap out my stock camber bolt?
    STU 17
    WATCH THIS
  9. #22
    Jun 2006
    Nor Cal
    Quote Originally Posted by SubaruWRC View Post
    Why isn't that a camber bolt?
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  10. #23
    Jul 2012
    Rocky Top
    That is a camber bolt. They are oval shaped and smaller than the holes to allow for adjustment.
    ...right?
  11. #24
    May 2007
    New Orleans
    Looking at some other alignment threads the bolt is supposed to have a notch by the head and a tab. This one did not. They showed the the eccentric bolts they had and it was shaped just like the ones posted here http://forums.nasioc.com/forums/show....php?t=1590221
    STU 17
    WATCH THIS
  12. #25
    Jun 2006
    Nor Cal
    Only aftermarket camber bolts have the notch and tab. That's what my rears look like.
    Trust me that's a factory front camber bolt.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  13. #26
    Jun 2006
    Nor Cal
    Pull the front bottom bolt and compare them. You'll see right away the difference.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  14. #27
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Wow double post over 1 hour time difference.
  15. #28
    Jun 2006
    Nor Cal
    Quote Originally Posted by A265 View Post
    Yeah tapatalk error
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  16. #29
    May 2007
    New Orleans
    So there are no tabs or anything to to align it to. How does this camber bolt work?
    STU 17
    WATCH THIS
  17. #30
    Jun 2006
    Nor Cal
    The only reason the aftermarket bolts have tabs to align them, is because they are so undersize for the hole they are going in. They do this to get maximum adjustment ranges in either direction. Example, the factory bolt in the front will net from +.3 deg to -1.5deg while an aftermarket one could get you +2.5deg to -2.5deg.
    The principle they both work on is the same; the holes in the strut housing are smaller than the hole in the knuckle. The lobe on the side of the bolt pushes against the knuckle when rotated, and forces the centerline of the hole in the strut to move away from the centerline of the hole in the knuckle.
    The reason for the tab is due to the fact that since the overall diameter of the bolt is soo much smaller than the ID of the strut hole, you need the tab to help locate the bolt, otherwise it wouldn't work. The tab is a bandaid.
    Since the factory bolt was designed to work in the OEM application, they just sized and designed it correctly from the off.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
