serious wear on inner tread
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
This is a discussion on serious wear on inner tread within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So, all four of my wheels are wearing badly from the inner edge of the tire to about 1 inch ...
    The Maestro WRXcritter's Avatar
    Jun 2012
    Indiana
    So, all four of my wheels are wearing badly from the inner edge of the tire to about 1 inch in toward the middle. I'm at 18k miles on the tires. The tire shop seems to think that it's because of the factory camber setting, due to it being a sports car. They want to adjust the camber to get the tires more vertical, thereby producing a more even wear on the tread. So my question is, has anyone else experienced this and is it normal? Also, would you consider have the camber altered to buy a few more miles on the tires? I don't do auto-cross, but I also don't want to lose any of that "hold the road in a curve" experience either. Opinions welcome!
    2013 Subaru WRX named BlueRex
    2003 Jeep Rubicon, special zombie apocalypse edition
    The high amount of negative camber on your car is in the rear, which isn't adjustable. That shop doesn't know what they're talking about.
    The lack of negative camber up front vs rear is why the car has a natural tendency to understeer.
    Resident Tuner @ WTF Tuning
            MainFrame's Avatar
    Austin, TX
    What is your camber currently at?
    Jun 2012
    Indiana
    hmm, i don't know what it's set at. And That would probably explain why they all four are like that because I have had them rotated on a regular schedule.
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    Isnt there a way to adjust the rear? I know its def not cheap.
    ¯\_(ツ)_/¯
    Kunal - Ordered 2015 DGM WRX
    Photographer | Dancer | Tech Nerd | The Stink-Eye Mob #7
    First Mods: What and what not to do
    2011+ Big Mod Thread
    How to Buy a Used WRX or STI
    Complete USED WRX Buying Checklist
    Jun 2012
    Indiana
    so now that we've determined the negative camber is standard, are other people's tires being eaten because of it? is there something i could do with tire pressure to ease the effect?
    Quote Originally Posted by kprugbyplaya
    Without $$ hardware, it's not adjustable. It's not like the older MYs where a $30-40 set of camber bolts did the trick.
    Registered User Soobvirgin's Avatar
    May 2012
    San Diego
    Quote Originally Posted by WRXcritter View Post
    You didn't mention whether you've had the tires rotated from front to back in that 18k miles. If you have, the inside wear could just be caused by the wheel alignment being off at the front. If the tires are only wearing on the insides, then the wheels are towing out too much - a simple adjustment. If you've never rotated the tires and all four are wearing on the insides... I have no clue.
            MainFrame's Avatar
    Austin, TX
    To an extent.. if you run low tire pressure the outside edges will wear, high pressure the center will wear. I run higher pressure than most (37 front 36 rear). Higher pressure improves fuel economy and reduces traction (reducing strain on the driveline).
    May 2012
    San Diego
    Yes, too high pressures will wear the center, but low pressures will wear both edges. A tire doesn't just sag on one side. If tires on either side of the car are wearing in the same way - both inside or both outside edges - it's an alignment issue.
            MainFrame's Avatar
    Austin, TX
    You didn't need camber bolts on the GD, the stock bolts are already adjustable (as you know). From what I remember, I was able to dial it anywhere from -1.4 to -.9 (or less, I forget).
    Quote Originally Posted by Soobvirgin View Post
    Right, but no one was ever talking about pressure causing the wear.. if higher pressure is going to alleviate wear on the outer edges, then obviously it will alleviate wear in the inner edge (as well as the outer edge). Higher pressure will make things better for his situation.
    Of course if the wear is that drastic then something else needs to be done.
    May 2012
    San Diego
    Ok, I'm confused, because you were the one who mentioned tire pressures originally But I'm not sure higher pressure will make things better for him if his alignment is off.
            MainFrame's Avatar
    Austin, TX
    nope
    May 2012
    San Diego
    nope
    Ahh.... I see. Sorry, missed that. I blame it on lack of sleep.
            MainFrame's Avatar
    Austin, TX
    I know all about that.. there's a reason why I'm usually the first on/last off in chat.
