2011 STI Suspension on a 2011 WRX
Results 1 to 8 of 8
This is a discussion on 2011 STI Suspension on a 2011 WRX within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I have a chance to get stock 2011 STI suspension for fairly cheap to install in my 2011 WRX. 1. ...
    Oct 2010
    Seattle WA
    1. Do the STI coilovers just bolt on a 2011 WRX?
    2. Is there that much difference between the OEM WRX and STI to warrant an upgrade or should I hold out for aftermarket?
    I already have perrin swaybars and endlinks.
    Registered User 11blackwrx's Avatar
    Sep 2011
    Akron, OH
    not too sure about if it will fit or not, but i would probably just go aftermarket and get something good. most sti owners i know still upgrade the stock sti suspension
    2011 Subaru WRX Premium
    1988 Ford Mustang GT
    2000 Jeep Wrangler TJ
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    Go aftermarket. It will be a far better upgrade from the STI suspension.
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    AFAIK the STI suspension won't fit the WRX. Like stated above ,a good aftermarket strut/spring combo would be a better choice.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Oct 2010
    Seattle WA
    Cool, thanks for the replies. I'll save the money and time to do a more substantial upgrade instead.
    May 2007
    orlando flawduh
    The "Will this suspension part fit my car?" thread. - NASIOC
    ^ take a look at that link. it's very helpful and will tell you what will and will not work.
    desiree
    May 2010
    Pittsburgh, PA
    STi's don't come with what most people would call coilovers, fyi . Spring and strut setup still. It is different however. For example, the STi's use basically an inverted strut, where as the WRX uses a traditional, I believe.
    In all honesty, I'd recommend just going with an aftermarket suspension upgrade as well. Unless the parts are free, I wouldn't bother with the hassle of mix and matching parts that are compatible. I'd recommend a good set of sway bars and a nice custom alignment (zero toe all around, max negative front camber - with as little cross as possible). That should get you started without too much hassle =).
    2011 STi Build Log
    Registered User boone1186's Avatar
    Dec 2011
    Minnesota
    Koni yellow + swift sport =
    2010 WRB WRX
