Spring set up
Results 1 to 9 of 9
This is a discussion on Spring set up within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Looking for best option for either coil over setup or a cheaper route to eliminate the wheel dip you get ...
    Registered User Ryno17wrx's Avatar
    May 2013
    So Cal (LA County)
    Spring set up
    Looking for best option for either coil over setup or a cheaper route to eliminate the wheel dip you get with the stock wrx suspension... Want to lower it a little bit for a better look and stiffer setup for cornering. Not trying to be mr. Stance nation, I drive mountain roads and need functionality over looks. Any suggestions? And I will be running the stock wrx wheels and tires for now.
    not going to be a track car, but i do want legit performance for the twisty mtn roads if ya know what i mean.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    My recommendation? Stick with the stock springs until you are ready to upgrade your struts.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User SomeGoalie's Avatar
    Jan 2013
    Cleveland
    2nd this.
    May 2013
    So Cal (LA County)
    Ok prob should have worded this better... Looking for a full coil over set up. Not just springs.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by Ryno17wrx View Post
    So what are you looking to spend?
    Plan at least $1800 for coilovers.
    Also, will the vehicle be used primarily as a track car? If not, I would stick to a quality spring/damper combination, as that particular setup will be significantly more forgiving for the streets.
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    Here are two decent options for your car..
    KW Coilovers Variant 3 inox-Line Subaru WRX 2008-2013 35245015 at RallySportDirect.com
    Racecomp Engineering : Racecomp Engineering Tarmac 2 Coilovers for WRX (2008+)
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    Koni Yellows and RCE Black Springs
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    zax
    zax is offline
    Nov 2008
    ^^ Agreed with Robin. Excellent choices as far as Coilovers go.
    Facebook me here
    Jan 2013
    Cleveland
    You can also look into the GTWorx Bilsteins with RCE springs.
