Brake Pedal Feel
Results 1 to 8 of 8
This is a discussion on Brake Pedal Feel within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Just wondering if there was a way to improve brake pedal feel, possibly a screw or nut adjustment? Thanks in ...
    Registered User anpato's Avatar
    Jun 2012
    Brake Pedal Feel
    Just wondering if there was a way to improve brake pedal feel, possibly a screw or nut adjustment? Thanks in advance.
    2013 SWP WRX Sedan
    Hillside, NJ
    Invidia Catless Downpipe, Custom Short Ram Intake, Self Tuned Using ECU Flash, Romraider and Tactrix
            MainFrame's Avatar
    Austin, TX
    A master cylinder brace and braided SS lines will help with feel..
    Jun 2012
    Shouldve reworded, I was wondering if there was a way to decrease brake pedal travel.
    2013 SWP WRX Sedan
    Hillside, NJ
            MainFrame's Avatar
    Austin, TX
    New pads, master cylinder brace, ss lines, and good fluid. It will bite harder faster since there won't be as much play in the system.
    Jun 2012
    Any word on ATE Suberblue with stoptech pads?
    2013 SWP WRX Sedan
    Hillside, NJ
            MainFrame's Avatar
    Austin, TX
    Both are decent. Hawk HPS pads are good too.
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    I run the Stoptech street pads. the last set lasted 30,000 miles being driven pretty hard. initial cold bite is noticeably less than when warm but I only notice it when first pulling out of the driveway then never again. Much better than my friends 03 with stock pads.
    Either a larger bore MC or a smaller bore set of calipers.
    Firewall flex and hose swelling aside (not much on today's cars) the stroke is relative to the fluid displacement. A larger bore will move more for less stroke or a smaller amount of piston area will require less travel.
