11' rear endlink broke at the control arm. Replacement?
Results 1 to 4 of 4
This is a discussion on 11' rear endlink broke at the control arm. Replacement? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Just picked up an 11' wagon that already had whiteline sways and endlinks. I was greasing the bushings because the ...
    Registered User WrRexgoliath's Avatar
    Aug 2009
    Denver, CO
    Just picked up an 11' wagon that already had whiteline sways and endlinks. I was greasing the bushings because the previous owner failed to do so and they were squeaking like crazy. Anyway while I was underneath there I found a rear endlink to be busted. Also seems to be busted off from the lower control arm. Where the bolt goes through the control arm the steel is busted. It appears that there is a bolt that goes through the lower arm which I'm hoping is what I can replace without replacing the whole lower arm just to replace the endlink. I couldn't get a good look at it due to location. Was wondering if anyone on here had any issues like this or knows the setup of the lower arm?
    Thanks guys,
    WrRexGoliath
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Any pics?
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Aug 2009
    Denver, CO
    Not as of yet. I will try and post some on my next day off.
    Sent from my HTC6435LVW using Tapatalk 2
    Sep 2008
    If I'm reading this right, it sounds like a problem that I recently had.
    FAIL: Whiteline Endlink | MNSubaru
    Long story short WL Customer service is fantastic, and had a new set of endlinks overnighted and to me the next day. I got the newer KLC 182 style. If, however they don't refund or replace since you aren't the original buyer, I do have my other unbroken endlink (thinking the one you have) still and would work something out with you. It was on my car for a couple of weeks only.
