Warped wheels help
Results 1 to 5 of 5
This is a discussion on Warped wheels help within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hi I've managed to warp my passenger side wheels. Yes both front and back. The painful thing is when I ...
    Registered User DorBink's Avatar
    Sep 2009
    Houston, Katy
    Warped wheels help
    Hi
    I've managed to warp my passenger side wheels. Yes both front and back. The painful thing is when I hit 65+ mph my steering wheel visibly shakes. The guys at discount tire rebalanced my wheels and that helped with some of the shake (used to shake at only 50mph!). Anyways they pointed out my problem was I warped my right wheels.
    So I'm concerned if driving with these wheels will have any ill effect on my difs. It's currently not my DD so I'm not driving it while I pick some new rims. But I might be starting a new job soon and loosing my current company DD.
    Short question then is it bad to drive with bent wheels on the passenger side both front and back?
    Thanks
    Jared
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Yeah that is not safe. You need new wheels.
    Sep 2009
    Houston, Katy
    I'm still in control of the car at that speed the shaking steering wheel just takes the pleasure out of driving at that speed. So safety not being an issue should I expect any wear and tear on my differentials? I know mismatched wheels size can play havoc on the dif so I'm guessing misshaped might have some bad consequences.
  5. #4
    Nov 2012
    Quote Originally Posted by DorBink View Post
    First and foremost, it is not safe to be driving with warped wheels (especially at high speeds). Second, if you feel the shaking then it is not good for your car. You'll probably wear out the wheel bearings and most likely do some suspension damage as well. Not to mention your tires will probably wear out very quickly.
  6. #5
    Sep 2009
    Houston, Katy
    Cool thanks for talking sense into me. I need to figure out some new wheels sooner than later I guess... And jut park that car for now.
