Whiteline Front Sway Bar Weirdness '13 WRX
Results 1 to 5 of 5
This is a discussion on Whiteline Front Sway Bar Weirdness '13 WRX within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So a month or so ago I installed my brand new WL 24mm Adjustable front Swaybar and end-links on the ...
    Sep 2008
    So a month or so ago I installed my brand new WL 24mm Adjustable front Swaybar and end-links on the soft setting as setting.
    Issue: My WL Swaybar sits so close to the LCA (about 1/4") but doesn't rub as far as I have noticed so far. It is so close infact that I would not be possible to adjust it to the stiffer setting (front hole) without it rubbing. Is this issue normal for the rest of you?
    Feb 2013
    NH
    Did you ever find the answer to your question? how do you like the car with the bigger sway?
    Sep 2008
    I just crawled under the car this weekend and I needed to adjust the end link a little taller and it made the gap a bit larger, I'm guessing more like how it is supposed to be. The difference in the sway is night and day. The front I would do first if I had to choose to do it again, it stiffens up the front end and reduces the roll quite a bit. What kind of set up do you have?
    Feb 2013
    NH
    My set up is stock but looking to upgrade soon..Just reading post and trying to figer out what I should upgrade too.i was looking at the WL 24mm and the Eibach 25mm .. but still looking...how long have you had this setup on? did you do this upgrade your self?
    Sep 2008
    Had it on for a month or so. I have a brand new in box 24mm adjustable by Whiteline if you are interested.
    Sent from my SCH-I545 using Tapatalk 2
