Need opinions on suspension
Results 1 to 15 of 18
This is a discussion on Need opinions on suspension within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I'm going to install Koni yellow dampers and swift sport springs. Looking for opinions on whether or not i should ...
    Registered User boone1186's Avatar
    Dec 2011
    Minnesota
    I'm going to install Koni yellow dampers and swift sport springs. Looking for opinions on whether or not i should install an anti lift kit and aftermarket strut mounts in the front. Suggestions are welcome. To sum everything up: this car is a DD which may see the track a few times a year. What I'm trying to achieve is a setup which is upgraded from stock, keeps ride quality, improves handling and lowers the body slightly. Input is appreciated. Thanks.
    2010 WRB WRX
    Dec 2011
    Pottstown PA
    sounds like a nice setup, aftermarket strut mounts never hurt
    Marky Mark
    My bugeye build
    MinoskePhotography
    ALK will kill your classing in some motorsports; if you want to actually compete, this may not be the mod for you. That said, it's my favorite suspension mod, to date.
    Whiteline Com-C mounts wouldn't be a bad buy; slightly more than Group-N, and the ability to alter camber/caster. I'd just buy new rear OE mounts.
    Resident Tuner @ WTF Tuning
    Registered User mmiller2002's Avatar
    Nov 2007
    Ft. Worth, TX
    I like doing things in steps so that I can enjoy the sequence of improvements. Maybe try the Koni/Spring upgrade and see what that does for you. Strut tops may be good at the same time since the old ones have to come out anyway. I have the Com-C and like them (although one of the bearings may be creaking right now.)
    '02 WRX Wagon
    RCE wagon springs
    Koni inserts
    Com-C Top Mounts
    Kartboy Endlinks
    Sedan rear swaybar
    Others little stuff
    Dec 2011
    Minnesota
    I'm not that interested in being able to adjust my camber and caster to be honest. I just want to make sure I'm using a top hat that is upgraded from stock as in a group N rubber. I'm having trouble finding non-adjustable fronts and I've yet to find any strut mount for the rear besides OEM. It's a 2010 WRX by the way.
    2010 WRB WRX
    Quote Originally Posted by boone1186
    Alignment will go a long way to handling, just below tires. This is static adjustments, not like typical plates. I would fork over the extra 50% over the Group-N and get them.
    Dec 2011
    Minnesota
    So i understand, does the alignment shop utilize the com c's adjustments or me? Forgive me, I'm learning as I go.
    2010 WRB WRX
    Com-Cs will alter camber/caster based on installation orientation. So, it would be you that does rough tuning when you mounted them to the strut tower, and fine tuning of camber would be done via the OE camber bolts, by the alignment shop.
    Dec 2011
    Minnesota
    Well, I don't know what I'm doing when it comes to rough aligning...
    2010 WRB WRX
    LOL There are instructions that describe it. There are three orientations you can install them, and it'll tell you what each one is. As a general rule, you can't have too much caster.
    Dec 2011
    Minnesota
    Thanks for your help!
    2010 WRB WRX
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    COM-C's have a history of issues. Have those issues been remedied Matthew?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Quote Originally Posted by Sinister
    Not sure. I know a bunch of people that run them without issues (e.g., myco)
    Nov 2006
    Denver Metro Area
    Wasn't the problem with the rubber starting to tear away? Or am I thinking of a different tophat?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Nov 2006
    Denver Metro Area
    Kevin
    Moderator
    WRX Gas Mileage FAQ
