Is this plug-able?
Results 1 to 15 of 18
This is a discussion on Is this plug-able? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So pissed. These tires are practically brand new. Its been this way for about a week now & im just ...
    Apr 2013
    Atlanta
    Is this plug-able?
    So pissed. These tires are practically brand new. Its been this way for about a week now & im just now noticing pressure release. Its holding pressure, just not like it used to.
    I can't afford getting a whole new set of tires so I'm probably gonna try and plug it this weekend anyways but Im worried about its performance. It's so close to the wall of the tire...
    Any thoughts?
    Moderator Donkey's Avatar
    Da boonies,Va
    I would plug it.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Registered User mfigge2's Avatar
    Jun 2012
    IA, US
    Technically no. Depends how daring you are. I would be nervous about a blowout while doing some hard and fast cornering...like an on ramp. It's a shame there's no road hazard protection offered when you buy the car like you can get when you buy tires.
    RMA_tire_repair_guidelines
    '13 WRX Limited PBP hatch
    2012 Suzuki V-Strom 650 Adventure
    Apr 2013
    Atlanta
    Quote Originally Posted by mfigge2 View Post
    I can be daring at times but I don't drive my car too often. I'm only on the road an hour a day through the week for work, tops.
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    Road care warranty thing on the tires?
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
    Apr 2013
    Aurora, IL
    If they are as new as you say you can just get just the one tire replaced.
            MainFrame's Avatar
    Austin, TX
    I had a screw in one of my RE-01s in the exact same location. I plugged it.. then a week later the sidewall buckled and $1150 worth of tires were ruined.
    Registered User thegamer1587's Avatar
    Oct 2012
    Western Pa
    Quote Originally Posted by Grymmfrost View Post
    +1 If they're basically new, just replace that 1 tire.
    Registered User marx's Avatar
    Jan 2013
    Maine
    I would not plug it. For one thing I think its illegal to just put a plug in now and go in most places. Now they have a patch plug combination that work really well. I used to do tire work its the better and safer way to go. They will break the trire down and work from the inside of the tire it covers and seals a much bigger area not to allow moister to get into the steel belts and corrode them. Any good tire shop should be able to take care of that.
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by marx View Post
    Most shops would not touch something that close to the sidewall. Cannot patch the inside because of the location of the puncture.. and I believe it may be outright against regulations for them to do work on a puncture like that.
    Apr 2013
    Atlanta
    The Kaufman tire here in ATL does tire repair for free, which sounds nice, but it also sounds like the plug/patch would work better/safer.. I know it looks really close to the side-wall but it really isn't.. That being said I don't think there's enough room to patch though.
    Currently, my tire is holding close to 29psi w/nail... its visibly noticeable but hasn't gotten worse, this makes me feel like if I can get the tire to a state where it will at least hold the appropriate psi then Im golden. Again, I rarely drive this beast.
    Anyone else have experience with a nail/screw this close to the wall?
    Dec 2011
    Pottstown PA
    Quote Originally Posted by thegamer1587 View Post
    +2 risky business and youre putting others in danger as well as yourself
    Marky Mark
    My bugeye build
    MinoskePhotography
    Jun 2012
    IA, US
    +3 on replacing the one tire. It's worth the $200 for peace of mind as you're going 60 mph around an entrance ramp. $200 is cheaper than having an accident and having to pay your deductible.
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Pull the tire off the rim and add a washer and nut... Otherwise the screw WILL come out and you're stranded...
    Nuts... Just replace the tire, at least you wouldn't need to replace the whole set. This is an easy one. It's a lot harder when the tires have a good bit of wear - then you'd have to consider the whole set of 4!
    Apr 2013
    Cohoes New York
    U can definitely patch that from the inside I wouldn't use a traditional plug or even a patch plug if u drive hard but a hole that small can b sealed up by someone who knows their way around a quality patch
