Sway bar install
Results 1 to 4 of 4
This is a discussion on Sway bar install within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I only have 2 ramps and my stock wheel jack (which I dont believe can jack high enough to get ...
    Sep 2008
    Sway bar install
    I only have 2 ramps and my stock wheel jack (which I dont believe can jack high enough to get on ramps).Can I just put the front up on ramps and install the FSB and end links then the rear?
    Sent from my iPad using Tapatalk HD
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Yes, that is how I installed mine. I did my fronts first since it takes a bit more time, then went out for a quick drive and returned to complete my rears. Having a spotter as I reversed up the ramps was nice, but I've done it without since then. I'd recommend swapping your end links at the same time.
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    The suspension has to be under load. I did mine on 2 ramps. For the front drove the car onto ramps & for rears reversed on to them.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Sep 2008
    worked,thanks for the tips! Night and day difference.
