08 WRX Brembo brake swap - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on 08 WRX Brembo brake swap within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; True enough torque but he could be a second status baller like myself with a little more money in his ...
    Registered User wrx50's Avatar
    Jun 2012
    MA
    True enough torque but he could be a second status baller like myself with a little more money in his pocket
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    The 2006/2007 4/2 pots don't even come close to the performance of Brembos... The pad area is significantly smaller. While an upgrade over the 2/1pot brakes in the 2008+, not by much.
    Sent from my Nexus 7 using Tapatalk HD
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jun 2012
    MA
    I disagree from a performance standpoint. It may be the stop tech pads and the fluid change that did it but I can guarantee the stopping power compared to stock is not even close to comparable
  5. #19
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by wrx50 View Post
    It's the pads and fluid. Pad area between the 2/1 and 4/2 are nearly the same... the extra pistons help even out the pressure, but it's not a considerable increase. Brembos, OTOH, are a significant improvement.
    Facebook me here
  6. #20
    Jun 2012
    MA
    I see. Well either way I'm happy with the way my Wrx stops now
  7. #21
    Registered User MrManny's Avatar
    Sep 2012
    Houston TX
    And bigger rotors means more braking torque
  8. #22
    Sep 2012
    Houston TX
    Does anyone know how to save a thread? Cause I've noticed they go away after a while and i probably wont start this til after I do my coilovers and get new tires
  9. #23
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    It won't disappear. You will just have to search for it
    Lead Wrench @ WTF Tuning, LLC
  10. #24
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by MrManny View Post
    Even the stock brakes provide plenty of brake torque... Enough to lock the wheels under full braking. Larger pad area helps to improve thermal efficiency, as does the larger rotor.
    Facebook me here
  11. #25
    Dec 2004
    Medford, Oregon
    which, to be fair the rear LGT brake rotor is a much larger rotor than stock 02 to even 11 wrx.
    Which brings up another good point, if you want to increase brake efficiency without breaking your bank account you can upgrade to LGT front and rear brake calipers and rotors. larger front rotors and a larger rear also ventilated disc brake will increase over your stock brakes by quite a bit especially in autox or daily driving activities.
  12. #26
    zax
    zax is offline
    Nov 2008
    Great point Toboggan!
    Facebook me here
  13. #27
    Sep 2012
    Houston TX
    O good point...I guess i'm trying to prevent brake fade then cause it's happened to me before...and Ill look into that but i dont do auto X, I do circuit
