Results 1 to 15 of 19
This is a discussion on Steering wheel, slight vibration... within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Morning all. I'm not sure if I'm paranoid but... The other night I hit a big pothole. Since then I've ...
    Registered User CaQuin's Avatar
    Jan 2012
    Queens, NY
    Morning all. I'm not sure if I'm paranoid but... The other night I hit a big pothole. Since then I've been constantly being anal about the ride of the car. Since then I've noticed a slight pulse/vibration on the steering wheel. It's not violent, but very light/faint. It usually comes it if over 50mph. Now I don't know if its always been there. Maybe I'm just very paranoid. Hopefully it's normal.
    Does it pull to the side? No... Got it checked, got a wheel alignment, and got the tires balanced. Still there.
    Any advise? Is it normal harshness of a 12 wrx wagon?
    Thanks!
    Registered User anpato's Avatar
    Jun 2012
    Did you get your tires rotated? Did you notice of you bent the rim when you hit the pothole? These could cause vibration. If everything checks out then could just be the roads.
    2013 SWP WRX Sedan
    Malvern, PA
    Invidia Catless Downpipe Torqued Performance Stage 2
    Aug 2012
    Bristol, CT
    were they balanced right? lol sounds simple and stupid but can easily be screwed up.
    sorry this is actually hard to diagnose without feeling the vibration yourself.
    wheel balance issues, loosened suspension somewhere maybe....choppy tires...bad roads...wheel bearing...
    hell even if your tire pressures arent right itl throw the balance off you know?
    Registered User Wussola's Avatar
    Sep 2011
    Providence, RI
    Quote Originally Posted by CaQuin View Post
    Thanks!
    I had this same exact problem with my 2011 WRX one month after purchasing it. I brought it to the dealership multiple times. They kept telling me that is the way the WRX drives ... however, it didn't have the vibrate/unsteady shake prior to the bump I hit on the highway. It's also not the "feel of the road" because it's always there when I drive over 60 mph (new tarmac or old tarmac). I've had my tires rebalance multiple times, an alignment and rotations. To me there seems to be a problem wheel, the one that whenever they re-balance - it is the one that has the most weight on it and moves around with each rebalancing attempt compared to the other three tires. I was especially pi**ed off because I purchased the extended warranty that covered the wheels and they still wouldn't replace the one that was the problem. I finally gave up and still have the vibration today. I do notice that if I drive over 80 mph then it goes away ... so I just drive over 80 on the highway
    I'm now looking into purchasing 18" wheels, so my problem will be fixed soon.
    Hope you have better luck.
    2011 Subaru Impreza WRX (Premium) | EFI Logics Tuned Stage 3 on 93 (310hp/324tq) | Cobb SF CAI | Cobb Catted Downpipe | Borla CBE | PW TMIC | Grimmspeed EBCS | Grimmspeed AOS | DW 65C Fuel Pump | Grimmspeed Light Weight Pulley | SPT Short Shifter | JNA Front Lip | EPIC Performance Springs | SMY Cluster w/ Boost & Oil Pressure
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    When I bought my used WRX it came with brand new tires. There was a shimmy in the steering, speed related that indicated off-balnce right away. The dealer had to re-balance and that was not done when I went to pick it up. So the dealer paid a shop in my town to do it. I think the tires where originally balanced, the new looking weights where there. But then someone hit the gas hard and slipped the newly installed tires on the rim. Since re-balance and careful driving for a bit, there hasn't been any more issue.
    Registered User Soobvirgin's Avatar
    May 2012
    San Diego
    Quote Originally Posted by nsibanez View Post
    +1
    Quote Originally Posted by Wussola View Post
    ...it's always there when I drive over 60 mph... if I drive over 80 mph then it goes away.
    If you can drive through it, it's balancing. Did you try taking the car somewhere other than the dealer to have the wheels balanced? If the balancing machine isn't calibrated regularly, it doesn't matter how many times your wheels are balanced or how good the tech doing the job is, it's never gonna' be right.
    Jan 2012
    Queens, NY
    Thanks for the replies. I brought it back to the place where I got it balanced and realigned... They rebalanced it, it somewhat made it better, they said that the tires are feathering out which contributes to the vibration. I'm feeling a faint pulsating randomly but much better now. The guy said the only way to get rid of it completely is with a new set of tires however the life of it is still good. If I can take the vibration, there is no need to get a new set of tires.
    May 2012
    San Diego
    Well, perhaps. But the vibration could be putting excessive wear on your wheel bearings. Not that I'd be excited about buying a new set of tires when the current ones still had life in them.
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    Funny I have the same issue.
    I took my car to the dealer and he rotated my tires. front ones to the back and vice versa.
    When we looked under my car, the inside of the front tires had more wear than any part of the tire. And the inside of my front right tire had the most.
    So this is def an alignment issue.
    So last Wednesday, the mechanic rotated them and the steering wheel wasnt vibrating or w.e but it was still vibrating when breaking gradually at high speeds
    Im going back again next wednesday to get my alignment and balancing done. I really hope this will fix the vibration when gradually braking.
    May 2012
    San Diego
    Quote Originally Posted by kprugbyplaya View Post
    I would agree that if your front tires have worn on the insides, that's an alignment problem (toeing (towing?) out too far), but I can't see how a vibration under braking could have anything to do with with wheel balancing or alignment. Neither of those things change when you press the brake pedal. A vibration that happens only under braking is usually a warped brake disc.
    Nov 2012
    Lansdale, PA
    Having a car with badly aligned wheels also leads to other connected problems. Your brake shaft does not work to optimal levels. The tendency to pull to one side due to uneven tires causes problems in the steering system. It also leads to uneven braking.
    But yes def good point on the rotors being warped (that would be my first judgement). I was going to have them check that out just in case next wednesday.
    I mean I would assume that the rotors was the first thing he checked the first time I went to him.
    Aug 2012
    Bristol, CT
    The vibration while braking at highway speeds indicates warped rotors.
    Sep 2011
    Providence, RI
    Quote Originally Posted by Soobvirgin View Post
    +1
    Yes I did ... and of course when they put my car up on the lift - they didn't adjust the lift correctly and bent/damaged my side skirts. Vibration problem still persisted
    May 2012
    San Diego
    Don't you just love it when you pay professionals to do a job and they damage something? Nice.
    After reading your original post again, with regards to one wheel needing noticeably more weight to balance than the others, it does sound like you damaged the wheel in some way. I'm sure someone's already tried, but you could check the bearings. Jack the car up and grab each wheel with two hands - one at the top and one at the bottom. Try rocking the wheel back and forth away from you. If there's any play, you could have a faulty bearing. But, my guess is probably damaged wheel at this stage.
    Aug 2012
    Bristol, CT
    ya sounds like a bad wheel...bent rim in anyway...
    try keeping that wheel in the rear maybe?
