Results 1 to 10 of 10
This is a discussion on 2011 WRX with Whiteline Rear Sway Bar and Kartboy Rear End Links within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hi all, During the past weekend I semi-successfully installed the 22mm Whiteline Rear Sway Bar with Kartboy Rear End Links ...
    Sep 2010
    Talking 2011 WRX with Whiteline Rear Sway Bar and Kartboy Rear End Links
    Hi all,
    During the past weekend I semi-successfully installed the 22mm Whiteline Rear Sway Bar with Kartboy Rear End Links on my 2011 WRX hatchback. It's successful because most things went in smoothly --- didn't have too much trouble with most of the bolts, and most importantly, I'd like to report that the End Links fit perfectly with the WL sway bar. No extreme angle at all. I've learned that some people experienced the weird angle problem with this combination, so I guess they must have changed something to fit better. Just wanted to let you know.
    And the "semi-" part, is that I just couldn't take of the inward lower control arm bolts. My impact wrench didn't move the things at all, even though I've sprayed PB Blaster multiple times over a period of 3 days. So I gave up on the supporting brace. It should be okay without the braces, right?
    Now the car feels very stable and tight during corners, and there's no NVH increase at all. No noises, squeaks or bumps of any kind. So far so good! It's definitely a very noticeable improvement over the stock rear sway bar.
    msharp
    2011 Subaru WRX 5-Door
    2008 Mazda RX-8 GT
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Welcome to the club. I wasn't able to get the rear lateral link bolts off either. Although I did not use air. I tried a breaker bar & an impact wrench & only managed to strip one of the bolts. So I let it be. Figured I'd let a shop handle it later. Haven't had any issues with not having the brace.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    Sep 2011
    San Anselmo, Ca
    I'm surprised you had problems with that bolt. I was worried when I did sway bars this past weeekend that it would be a problem. Used a 16" breaker bar and the nut came right off. Here's a pic:
    Sep 2010
    How old is your car? How come your underbody looks so clean, while mine has lots of rust on it (not shiny at all). Maybe yours is much younger? In any event, I am jealous!! :-)
    2008 Mazda RX-8 GT
    Jan 2012
    Philly Area
    Quote Originally Posted by msharp View Post
    Srsly! That is astonishingly shiny and clean!
    - William
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    I had the exact same issue. 18" breaker bar did nothing. Don't have access to air, so I saved them for next time it's at a shop.
    Registered User 11blackwrx's Avatar
    Sep 2011
    Akron, OH
    im going to be doing sway on mine soon, cant wait
    2011 Subaru WRX Premium
    1988 Ford Mustang GT
    2000 Jeep Wrangler TJ
    Sep 2011
    San Anselmo, Ca
    Mine is an '11. Cleaned a lot of it with WD-40. Put wax on some of it (I know...it's a sickness....can't help myself).
    Could also be that our Nor-Cal winters aren't as severe as other parts of the country.
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    Jesus, I would lick the bottom of that car.
    Sep 2011
    San Anselmo, Ca
    Quote Originally Posted by kprugbyplaya View Post
    Would have saved me some work
