Your shocks are underdampened from the factory. I wouldn't install springs without installing struts as well. You're looking at ~$1K if you want to lower it.
This is a discussion on Lowering questions within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I have a 2013 wrx sedan I would like to lower only about an inch, any one have any comments ...
I have a 2013 wrx sedan I would like to lower only about an inch, any one have any comments or suggestions on any suspension brands? and how fast my shocks would wear out at an inch lower? Thanks!
Firstly, your car has struts, not shocks.
Handling dynamics is a delicate balance between damping, spring rate, suspension geometry, and rubber. As might be presumed, selecting a very high spring rate without accounting for damping will cause the suspension to become underdamped, leading to a very bouncy ride quality. However, there are many "lowering springs" that are intended to run with OEM struts and are merely for looks. These springs have anywhere between a 25 a 50% increased spring rate with a mild drop. It's unlikely this margin of increase will upset the handling balance to a large degree, though your struts WILL wear faster as you suggested.
If this is merely for looks, go for it. If you are concerned with handling, I would address your tires and alignment first, as those components will improve your handling to the highest degree.
Facebook me here
Originally Posted by Mikie13
-Noah
2009 Spark Silver Metallic Sedan - Stage 2+
Build Thread: http://www.clubwrx.net/forums/builds...wrx-sedan.html
Please read:
08+ WRX Regular Guy Springs
"Regular Guy" are "Blacks"
Racecomp has taken feedback from the casual enthusiasts of the GTWORX Bilstein kit and produced a more daily driver friendly spring that still has a good combination of ride quality without sacrificing much track performance in comparison to the more agressive Yellows. Racecomp Engineering's goal was to help cure the understeer that adds to lap times at the track and autocross course. Hearing reviews that the Yellow spring traditionally paired with the WRX Bilsteins was too harsh for some, a less aggressive performance spring has been produced that retains available bump travel and works in conjunction with the rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit yet retains ride comfort. Due to the lower spring rate compared to the Yellows, the RCE Regular Guy springs may be used with stock struts on the 2011+ WRX.
Offers 3/4" drop front and rear. Spring rates of 275lb Front / 250lb Rear
Facebook me here
I know they are able to be used with stock struts. I wanted to make sure because of what ej257 said about using different struts with aftermarket springs and because I have basically only seen reviews of them with non oem struts.
-Noah
I wouldn't want to do the install/alignment twice. While they were apart, I'd throw a set of Konis on.Originally Posted by wrx650
Please read closely.
Clearly this states "on the 2011+ WRX." Makes no mention of the 2008-2010 WRX. To me, this means that the 2008-2010 WRX require matching struts. Best I can say is to give TiC a call, as they are more-or-less experts on suspension in Subarus.Due to the lower spring rate compared to the Yellows, the RCE Regular Guy springs may be used with stock struts on the 2011+ WRX.
Facebook me here
-Noah
http://www.racecompengineering.com/i...or-09-wrx.html
Rce site says 2009+. That's weird that the tic says 2011+. Is there any difference between the 2009-2010 a struts and the 2011+ struts? I didn't think there were any.
-Noah
Facebook me here
Ok. My guess is that when I get around to doing this, I will probably get new struts to go with them. I have about 55 k on mine. Probably wouldn't hurt to get new ones when I get the springs. I will talk to the tic guys though before I do anything. Btw I love your avatar lol
-Noah
i put epic springs on my 2011 today,(designed to work with factory struts) lowered it about an inch. front and rear are now level and got rid of all the body roll. Im very happy with them
back is only squatting in this pic because i have the factory wheels and suspension in the back seat and trunk. leveled out perfectly once i took them out.
