I believe that since are retaining your stock calipers and pad size, you will remain in the STU, but this is as far as you'll be able to push the car brake-wise before you'll qualify for SM. You might want to consult SCCA regarding the regulations, however.
Regarding the kit: pads, rotors, SS brake lines, and good fluid is a common and excellent upgrade. Make sure to stay away from drilled rotors.
LinkBack URL
About LinkBacks
