Take it back man. That is some shoddy work from the dealer.
This is a discussion on 2002 Control arm torque specs? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Had a quick question. Just got car back from dealer after "fixing" the control arm recall. Looked under to make ...
Had a quick question. Just got car back from dealer after "fixing" the control arm recall. Looked under to make sure everything was alright and nice and tight and found this -__- i could only get it so tight with no lift, not getting under car. So does anyone know what the torque spec is? Ill be searching for it but just wanted to see if anyone knew to make my search easier. Thanks!
yea not going to take it back to them. going to go for another dealer for an ABS ECU replacement and just ask them to tighten to spec while its on the lift
Wow that's dangerous. Someone should be seriously reprimanded for that folly. Mark, take it back to the dealer that did the work, if not for you, for someone else's safety.
Sent from my Nexus 7 using Tapatalk HD
Facebook me here
Originally Posted by Mikie13
