Results 1 to 8 of 8
This is a discussion on 06 WRX TR Upgrades? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I own an 06 WRX TR that I have had for a couple years and I am done with the ...
    Jan 2013
    06 WRX TR Upgrades?
    I own an 06 WRX TR that I have had for a couple years and I am done with the warranty now. I wanted to maybe do some simple upgrades like suspension or exhaust. I have some gauges from an 06 tc I turboed (AFR gauge, Boost, and exhaust temp). I was wondering if I could get some input or advice on where to start. I do know the first thing I will change are the brakes, upgrading to some slotted and drilled rotor, simply because my current rotors have a small warp from a couple close calls from Missouri bad drivers. Any advise would be great and I dont have a lot to spend as I just bought my wife a new car. Thanks in advance.
    Jan 2013
    Anyone have suggestions on a good set of rotors to go with. I was looking at some Hart slotted and drilled rotors.
    Skip slotted and drilled rotors; just get a set of blanks like Centric Premiums.
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    Skip the rotor. Just get good pads, stainless steel lines and good fluid.
    I personally have Hawk Ceramic Pads and Motul 600 RBF. I have the lines but haven't put them on yet due to not having a flare nut wrench set.
    My "Build" Thread!
    2006 WRX TR
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Jan 2013
    Well the only reason I want rotors is to replace the ones I have, which have a little warp. I get some shake when braking at high speeds.
    Quote Originally Posted by KDuckWRX
    Stick with blanks.
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    Don't go the slotted or drilled route. A lot of ppl think. Oh we'll Porsches and the like have them from the factory so they must be better. Well there's a reason a brake job on a Porsche cost over $1000. Those $50-$60 slotted rotors arent made to the same standards as an oem like Porsche does. Buy a good set of centric premium(as already mentioned) or brembo blanks. Hell to be honest I'd install factory replacement autozone rotors before I went the drilled route.
    Jan 2013
    Ok so I got some centric plain rotors. The reviews are great on these by the way.
    I also just thought about gathering parts for the timing belt and pulley change. And after some research I realized the water pump should be changed as well. So I think this will be my next big project, since the car has 75k, it won't hurt to get ready for that.
