Page 1 of 3 123 LastLast
Results 1 to 15 of 41
This is a discussion on Coilovers or lowering springs within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I'm looking for something to stiffen up the ride in the '12 wrx w/min drop. Which is better springs or ...
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    I'm looking for something to stiffen up the ride in the '12 wrx w/min drop. Which is better springs or coils?
    A car is only as good as its driver
    Moderator Donkey's Avatar
    Da boonies
    With the information provided springs is a no-brainer unless you enjoy just blowing $$$$$$$. A good set of springs would cost you a 1/4 of what a set of good coil-overs would cost.
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by SubiEj255 View Post
    That's a highly subjective question. What are you looking to do with the car? Track, DD?
    Coilovers are superior for tracking, but you must purchase a decent set to justify the cost over springs/struts. If you want a decent set, they will be setting you back > $1800. Alternatively, a good spring/strut combo will set you back about $1000. Often, the linear springs of a coilover set have an exceptionally high spring rate which makes them counterproductive for daily driving. Many cite "adjustability" as the reason for purchasing coilovers. While coilover damping and ride height CAN be adjusted, many don't realize the suspension requires an alignment after each adjustment. Therefore, this is not a real advantage over spring/strut combos.
    One thing that stands out is you're looking for a stiffer spring with very little drop. Therefore you are in the same position as I. There are few springs that have a higher spring rate but sit at stock ride height. One company I did find that produced springs close to stock ride height was King Springs King Springs Automotive Aftermarket Springs
    Facebook me here
    Jul 2012
    Baltimore
    If you're referring to track as auto x then no; drag, then yes. I feel like the stock ride in the wrx is really soft. While speeding (pulling logs, 1/4 runs etc) I can feel the body roll. I just want to minimize that. I don't enjoy wasting money, so that's why I'm trying to figure out which is better for me out of the two.
    Dec 2011
    Pottstown PA
    sounds like youd be content with a good spring strut combo. search on here more, theres a good amount of threads here with the info your looking for.
    Jul 2012
    Baltimore
    Quote Originally Posted by Ruh Roh View Post
    Will do. So you're saying its best to get both springs and struts?
    zax
    zax is offline
    Nov 2008
    ok.... so why not go with some good sway bars?
    Facebook me here
    zax
    zax is offline
    Nov 2008
    You picked the wrong car for drag racing...
    Facebook me here
    Jul 2012
    Baltimore
    Maybe I said that wrong, but I was under thee impression that sway bars minimize "sway" or left to right movement. If so I'm not looking for that.
    Jul 2012
    Baltimore
    Ok. Thanks for your comment....
    zax
    zax is offline
    Nov 2008
    Re: Coilovers or lowering springs
    No. They reduce body roll.
    Sent from my Nexus 7 using Tapatalk 2
    Facebook me here
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Epic springs w/ koni "yellows" struts here. It's about about a 1.5-2" drop and the firmness of the stuts is adjustable. For the price, I absolutey love the setup.
    Greg
    www.modmeets.com
    ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
    Mods Blog Post
    Friends don't let friends drive Mitsubishis.
    Jul 2012
    Baltimore
    How much was that setup & where did you buy it from?
    Jul 2012
    Baltimore
    I appreciate it. You're not far from me, we need to hook up & have a talk so you could school me on a few things.
