four front two rear pot convert for a 02 wagonX question about fitment
Results 1 to 11 of 11
This is a discussion on four front two rear pot convert for a 02 wagonX question about fitment within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; can the newer sti four/two pot squeezers from the sti's say 05 or 06 bolt on to a 02 wrx ...
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    can the newer sti four/two pot squeezers from the sti's say 05 or 06 bolt on to a 02 wrx wagon? any info/links to the proper forums, pics, help, much thanks!
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    Nope but, 06-07 WRX brakes basically swap directly over and they are 4/2 POTS
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by michaelwfox View Post
    No, they will bolt to the knuckle, but the OP will need new rotors with a 5x100 bolt pattern.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Nov 2011
    North GA
    02 WRX Wagons aren't 5x100?!
    You confused me. I was saying that No, STI stuff will not swap over but, 06-07 WRX stuff will
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    zax
    zax is offline
    Nov 2008
    Ah but the Calipers ARE a direct swap! The rotors are not
    Facebook me here
    Nov 2012
    ahh well. thanks guys thats a bit more work than i was looking for. maybe later, i have a leaking front caliper. great time for a easy blot on upgrade. ill search up the hole thing before i go WRautoXing this summer. still sounds like a easy job, but ill just replace the bad caliper for now as my brakes are otherwise newer(6 months ish)
    Nov 2012
    actually, dont mind the nevermind. better braking on the way from grimmspeed in the form of a master cylinder brace. nuts thats clever. i was ordering parts there anyhoo and splurged a bit. that should improve my stocker a bit.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by tirerob View Post
    Why is it too much work? Just buy the STi calipers and caliper bracket, then get 2004 STi rotors like this: DBA 4000 Series T-Slot Slotted Rotor Front Subaru STI 2004-2013 at RallySportDirect.com
    The rear STi Brembos require special rotors and adapters to bolt to the knuckle/ clear the parking brake shoe. However, Brembo fronts and H6 rears are a good combination.
    Facebook me here
    Sep 2012
    06-07 calipers are a direct swap over to 02-05 wrx's. SAME ROTOR.
    Here's proof:
    02 wrx wagon front rotor
    Centric Plain 120 Series Rotors
    07 wrx wagon front rotor
    I also know, because I did this exact thing to my 02 wagon. Only thing that won't fit are the stock wheels! (needs 5mm spacer to clear the calipers)
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by burnurass View Post
    Here's proof:
    We were talking about the STi Brembos.
    Facebook me here
    Sep 2012
    Ah I didn't read carefully. Usually when I see 4/2 pot I think of the 06-07 brakes.
    Thanks!
