Are winter tires necessary?? - Page 8
View Poll Results: What tires do you have for winter weather?
Voters
37. You may not vote on this poll
  • Kept Stock Summer Tires
    4 10.81%
  • Added All Season Tires with stock rims
    5 13.51%
  • Added All Season Tires with steel rims
    1 2.70%
  • Added Winter Tires with stock rims
    10 27.03%
  • Added Winter Tires with steel rims
    17 45.95%
Closed Thread
Page 8 of 14 FirstFirst 1234567891011121314 LastLast
Results 106 to 120 of 202
This is a discussion on Are winter tires necessary?? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Around my area having winter tires is a must. A/S is pretty much as good as stranded when a good ...
  1. #106
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    Around my area having winter tires is a must. A/S is pretty much as good as stranded when a good storm hits. We have mountain pass inspection points/tire chain stops. They check whether vehicles are 4WD/AWD with A/S tires and chains on before they let you pass(this will not happen in the WRX because of the small wheel well). If you have Winter Tires and 4WD/AWD then you're good to go 90% of the time.
    Attempt to do the same feat with summer tires is just pure stupidity and attempting the same feat with any A/S tires will get you sent back if you're not already stuck!!!
    (Winter tires bears the following snowflake on mountain logo right on the side wall)
    Attachment 109841
    I know I maybe starting to sound like a broken record, but the particular requirement above says it all.
    Summer Tires A/S tires A/S w/tire chains = Winter tires Winter Tires w/chains
    They are necessary for certain places and may not be for others. Non-mountain states may have never heard of such requirements. I guess this is just a proof of A/S (UHP A/S are still all seasons!) being inferior to dedicated Winter tires in extreme winter conditions.
    2011 WRX Limited Spark Silver (5 Door)
    Quick reply to this message Reply
  3. #107
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Quote Originally Posted by rurso01 View Post
    these are the wheels I am looking to put on the wrx with snow tires. which tire size would I need for this rim in 16" Wheel Details - Discount Tire Direct.
    Yes, those steelies are the ones that fit. Bolt pattern on the WRXs is 5X100.
    I run the General Altimax Studless in 215/55-16 on my 2011.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  4. #108
    Registered User rurso01's Avatar
    Oct 2012
    The TPMS light I'm assuming? and that would go away the moment I put on the stock tires again? sorry for so many questions just like to get everything right the first time.
    when I am searching for tires based on the rim size it gives me options for the bolt patterns to match the rim. The rim says 6.5 5-100/115. I know that 6.5 is the width, 5 is the # of bolts and the 100/115 is the mm between bolts.
    My question is when it says 100/115, is that the range I can go and still have it fit safely? Totally nub with tires/rims as if I needed to state that.
  5. #109
    Oct 2012
    Quote Originally Posted by rage-wrx View Post
    Okay gotcha, I'll go with 5x100 then!
  6. #110
    You had the regular Impreza (N/A) selected. You need to redo your selection for the WRX hatch.
    Yes
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  7. #111
    Aug 2010
    Yonkers/NYC
    The TPMS light will go off once you put the stock tires with TPMS sensors back on & drive for a couple of miles. Of course you will have to have the right pressure.
    The thing with TPMS sensors is that unlike other car manufacturers Subaru's quirky TPMS system cannot be set with a OTC TPMS reset tool.(Some say it can be with more expensive reset tools) You will have to take the car to the dealer each time you change over at the end of the season to have them reprogram the sensor. Hence the reason many of us don't get the TPMS sensors installed in the winter wheels.
    T0ny
    2011 WRX
    2012 FXT
  8. #112
    Oct 2012
    Do these come mounted and balanced from Discounttiredirect.com? It doesn't say anywhere on here
  9. #113
    KHP
    KHP is offline
    Oct 2010
    Reno, NV
    I got my tires from a local tire dealer for a little less than online retailers and I got TPMS sensors with my winter set. They reset the sensors for free at every seasonal change over because I bought the tires from them(Just an option if the OP is thinking of purchasing TPMS sensors).
    I'm OCD with panel lights lol. Other than that TPMS sensors are completely optional.
  10. #114
    Oct 2012
    Im OCD about that too but as long as I know the cause of the light I'm okay. If its the CEL then I can't stand that being on for any reason whatsoever.
  11. #115
    KHP
    KHP is offline
    Oct 2010
    Reno, NV
    That's where I got my tires from is Discount Tires brick and mortar store. If you found a good deal at their website you may want to check out whether you have them locally. You should be able to go to their store and get the same prices.
  12. #116
    Oct 2012
    nevermind... found it
  13. #117
    Aug 2010
    Yonkers/NYC
    I believe I saw an option where you select "No TPMS sensors with free mounting and balancing " after you select the tires.
    T0ny
    2011 WRX
    2012 FXT
  14. #118
    Oct 2012
    I have tried it like 10 times and cant get to anything that offers free mounting and balancing. I got to the screen where it talks about adding TPMS but unless its a tire/wheel package they have put together already, I can't get free mounting and balancing. Am I doing something wrong?!
  15. #119
    Oct 2012
    I figured out the problem: Q. The tires and wheels I want aren't offered as a package. Can I purchase them as a package?
    A. Yes!
    If the tires and wheels you are looking for are approved for your vehicle you can create your own package online. Search for tires and wheels using your vehicle then add them to your shopping cart. When you purchase a tire and wheel package we will mount and balance for free and ship it ready to be bolted on.
    When I select 13 wrx hatchback it only shows me tires/wheels that are same size as stock. It won't let me change the size I want no matter what I do!
  16. #120
    Aug 2010
    Yonkers/NYC
    What I did was,on the home page I chose Winter tires. Chose the ones I wanted,put it in the cart,then selected wheels & options & added to the cart. It came up together during checkout.
    If in doubt you can always just call them.
    T0ny
    2011 WRX
    2012 FXT
Closed Thread
