Rattling suspension, new struts.
Results 1 to 5 of 5
This is a discussion on Rattling suspension, new struts. within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; SO a few weeks ago I replaced my suspension because I had 90k on the struts and they began to ...
    Registered User Buzz's Avatar
    Feb 2007
    rochester
    SO a few weeks ago I replaced my suspension because I had 90k on the struts and they began to rattle when in gravel driveways and bumpy roads. After I changed all four struts with KYB Excel-G struts and Group N top hats, the rattle is still there and might be a little more. WHat could it be. I think its mostly in the left side of the car, and doesn't happen on turns, acceleration or breaking.
    06 TR, COBB AP2,,COBB DP, K&N sr, G200 CB
    Subaru factory short throw, Auto dimm Rear view, Factory fog lamp kit (self installed)
    AM cobalt gauges: WB fuel, oil press (elec), boost (mech,30hg-20+)
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    So does this only happen when the car is just rolling? Does it make a difference if ground is rough or smooth?
    Kinda sounds like a suspension connection, one of the rubber bushings holding things to the body. Like a control arm....
    Feb 2007
    rochester
    Quote Originally Posted by Ingo View Post
    It only happens on rough surfaces. Like gravel or crappy pavement.
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Did you make sure and place the springs in the correct position in the top hats? When you torqued them down did the spring switch position in the struts?
    Lead Wrench @ WTF Tuning, LLC
    Feb 2007
    rochester
    Quote Originally Posted by T0rque View Post
    We defiantly had trouble keeping the springs from moving out of position, however we thought we had them correctly positioned. Ill look into the possibility of the springs being rotated. Thanks.
