Results 1 to 15 of 22
This is a discussion on Stiffer suspension within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So I did a pull for a log and I noticed that the suspension is very soft. I have a ...
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    Stiffer suspension
    So I did a pull for a log and I noticed that the suspension is very soft. I have a 12 wrx. What suspension mods would you guys recommend?
    A car is only as good as its driver
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    usually the first recommendation is swaybars and endlinks, but that won't give you a stiffer ride.
    for that, i would suggest some springs and shocks. personally went with rce yellow springs, and koni inserts. other options are rce black springs, and blistein struts.
    Jul 2012
    Baltimore
    Where can I find these?
    Texas, United States
    - Turn in Concepts
    If you have any questions or want a recommendation, don't hesitate to give them a call.. they are very knowledgeable, and very helpful.
    Jul 2012
    Baltimore
    Which is better of the two in a stiffer ride? Springs or shocks?
    Quote Originally Posted by SubiEj255 View Post
    Neither/both... it is important to match your dampening force (shock valve) to your spring rate if you want to achieve good handling characteristics.
    Apr 2007
    8000' up in Colorado
    They do different things. You'll need both together so they're matched. You don't do one and not the other.
    Scott
    Jul 2012
    Baltimore
    Oh ok so both at the same time or could I do one and down the line do the other? Also how about coils?
    Jan 2012
    Philly Area
    You could do springs now and get the struts later. Problem is, they will wear out your stock struts and could do so quickly. Besides, why not only do the removal/install once?
    Coilovers are great, but you cannot plan to be frugal. You get what you pay for with them.
    - William
    If you're looking to spend $2,500+, then coilovers are a good option.
    Registered User starkall's Avatar
    Sep 2010
    Stiffer suspension
    You can get decent coilovers for the $1200-$1800 range. They work just fine for the street and stiffen up the car quite a bit and don't ride to harsh at all. I know because I've used plenty of them.
    Jul 2012
    Baltimore
    So either shocks and springs or coilovers. I think I'll got the spring and shocks route. What's a good drop for the springs with out going to low?
    As little as possible really.. RCE blacks or Swift springs are both good options.
    Jul 2012
    Baltimore
    Yea I don't want fender rub or whatever it's called. Only blisten shocks are good?
    I think your best options are either RCE springs with Bilstein shocks, or Epic or Swift springs with Koni inserts.
