Results 1 to 15 of 16
This is a discussion on I need help with rims within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I want to buy new rims for my new wrx. This car is my first car that'll i would have ...
    Oct 2012
    Newark/Hillside,New Jersey
    Exclamation I need help with rims
    I want to buy new rims for my new wrx. This car is my first car that'll i would have messed with.I want to buy new rims but i don't even know where to start. the rims on my '13 wrx is gun metal paint rim.. I dont know what they are called. I am fairly new into the "Detailed car game". They only company i know is BBS but i thought it would wouldn't go well with my subaru since i usually see it on a vw/hondas. but i want my car to have am aggressive look. so what are your opinions or preferences? Let me know..thank you
    BBS are a good choice. Also look at Enkei, O.Z., Speedline, and do a search for fitment info.
    Oct 2012
    what you mean by fitment info?how would i find it cause i everytime i type in anything with 2013 wrx it always pops up if i want to buy it links-_-
    Search "offset" because this along with width will determine whether the wheel will fit at all, stick out too much, etc. there were several fitment threads here recently.
    Oct 2012
    thanks
    Aug 2012
    Bristol, CT
    Some Konig is good. If you can find a good website you can usuallydo a search specific to year, make, model. Then can search by factory size or plus sizes. If you go plus sizes you'll need tires as well.
    Oct 2012
    Quote Originally Posted by nsibanez View Post
    thank you.. usually i dont find my year since my car is new but thanks for the help
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Koenig are not good wheels. Avoid them.
    The weight of a wheel can have a significant measurable effect on performance. The lighter, the better. Two solid affordable lightweights: OZ Alleggerita and Enkei RPF1.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Oct 2012
    Quote Originally Posted by Sasquatch View Post
    ill look into them... its finding that perfect rim
    Jul 2010
    Cincinnati
    Quote Originally Posted by Kevin Pedrosa View Post
    You could try searching 2011 and 2012 wrx, its the same car and might get you some results
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Oct 2012
    Quote Originally Posted by jd92677 View Post
    ok thank you.. searching 2013 is no help
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    you will want a wheel about 18"x9" et 44
    Lead Wrench @ WTF Tuning, LLC
    Oct 2012
    Quote Originally Posted by T0rque View Post
    if you dont mind explain what that actually means? cause by my understanding the rim is 18in with 9in depth?? whats the 44? ...i will get the concept and have an idea.
    Offset is the vertical displacement of the wheel's center from the hub. It can be measured in +\- mm, meaning the wheel will be displaced that much either direction. This is a rough explanation. There is a FAQ around somewhere.
    Dec 2004
    Your Mommas
    You can do several different options and several different widths. What I have found is exact proper fitment for the 11+ is an 17" or 18" wheel, 9" wide with an offset of 44. You can go with a 40, 38, 35 offset but that's just getting more and more poke. The 38 offset is where it starts requiring a little camber (but still within spec) and rolling rear fenders. You can also go with a 9.5" wide rim if you'd like but 265/35/18 tires fit great and they fit better on a 9" wheel
