What's better? bags or coil overs - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
This is a discussion on What's better? bags or coil overs within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by zax Any change in ride height will affect your camber and caster. This will need to be ...
  1. #46
    Aug 2012
    Tucson, AZ
    Any change in ride height will affect your camber and caster. This will need to be adjusted for the best possible handling.
    Most places don't even touch camber or caster.
  3. #47
    Oct 2005
    Late Devonian
    Quote Originally Posted by nsibanez View Post
    Caster is adjusted by various add-ons (e.g. tophats or plates, ALK). Camber is adjusted in custom alignments without additional parts in the front only, or with additional parts (usually camber bolts added for the rear, and or tophats again). At least for older years you can get significant improvement in the front camber with a good alignment (-1.2 to -1.5) - if you haven't done that yet it is the first thing to do.
  4. #48
    Aug 2012
    Tucson, AZ
    I'm saying some places won;t even bother adjusting anyting but toe
  6. #49
    Oct 2005
    Late Devonian
    This is true. That is when you know you are in the wrong place.
  7. #50
    Oct 2005
    Late Devonian
    Quote Originally Posted by Kevin Pedrosa View Post
    what sounded interesting? bag?
    That you can change the ride height and firmness on the fly. As said though, the negatives are there and likely outweigh this.
  8. #51
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    Then they are not aligning to factory specifications (our cars are more adjustable than just toe) and you shouldn't take anything but your lawnmower there for service. Any alignment shop worth their salt will set the car up any way you ask if other than to exact factory spec.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  9. #52
    Oct 2012
    Newark/Hillside,New Jersey
    so it wouldnt be good to put them in myself then
    Quote Originally Posted by mangostick View Post
  10. #53
    Oct 2005
    Late Devonian
    You have to get an alignment whether you do the install yourself or not. You should wait until they are fully settled (RCE springs will compress more over the first month or so).
    I highly recommend reading this and don't get factory specs.
    Alignment basics
  11. #54
    Oct 2012
    gladly will read it thank you
    Alignment basics
  12. #55
    Oct 2009
    What I meant when mentioning factory spec was that our cars have more adjustments that need attention vs just toe.
    SWP 2013 FRS
    SUCH IS MANGO!
  13. #56
    Aug 2012
    Tucson, AZ
    Save those treads!!!!!
  14. #57
    Oct 2005
    Late Devonian
    I knew you didn't mean factory specs were ideal. Your point still stands.
  15. #58
    Oct 2009
    My own car hasn't been set to factory spec in ... oh man.. a good 60K mi lol.. I've got a lil more camber up front and toe set to 0* all around.
    SWP 2013 FRS
    SUCH IS MANGO!
  16. #59
    Oct 2005
    Late Devonian
    Yeah I exceeded the reasonable wear rate on a set of Direzzas once I had the Com-C front tophats and had to back it down a bit. I have to look but I think I'm at -1.6 or -1.8 now and am getting even wear.
