What's better? bags or coil overs - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 59
This is a discussion on What's better? bags or coil overs within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Kevin Pedrosa everyone saying feal 441s then i started wondering if they bad for the streetif it ...
  1. #31
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    Quote Originally Posted by Kevin Pedrosa View Post
    everyone saying feal 441s then i started wondering if they bad for the streetif it rides hard... like my dad's truck has stiff suspension which makes feel everything..i want something in between not to soft not too hard.
    Then leave the coilovers out of the equation. Check the spring rates on any of the available coilovers .. 400lb/in+ on ALL OF THEM (you'll find they're listed in metric.. 8k roughly equals 435lb/in). That includes the Feals for our cars. Now you might be able to get Feal to put a lower spring rate on for better street ride but that greatly depends on the dampers adjustment as well. Spring and Damper work together and they have to be pretty well matched to get really good feel and handling at same time. To give you an Idea of how much stiffer coilovers are vs stock.. our factory fronts are 217lb/in rear is about same. You'd effectively DOUBLE the spring rate going with coilovers. It WILL ride stiff. GF has an 07 TR with BC's and on the full soft setting its tolerable but still very bouncy/stiff. BC's come with 8K springs (435lb/in)
    Check into GTworx/RCE These guys will not steer you wrong and there are literally a ton of people running their regular guy and yellow springs.
    GTWORX.COM : GTWORX/Bilstein Impreza WRX Cup Sport Kit
    There are wrx kits available, just aren't on the website yet. Catch is they wont be in stock until first week of dec (according to a recent email I got from them). I plan to run the regular guy springs (270lb/in front and 250lb/in rear) for a nice streetable setup that doesn't take my teeth out or shake my kidneys loose. If you're going to track the car.. the yellows are the way to go. Those are 330lb/in f/r and both the regular guy set and the yellows are the springs that Bilstien used to design and valve the struts for the GTWorx folks.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  3. #32
    Oct 2012
    Newark/Hillside,New Jersey
    but seeming to make a combo type set up will consume much time to find that good set up for you
    Quote Originally Posted by Ruh Roh View Post
    theres always going to be "better" everything, if you have the money for it... but feals seem like a great coilover. when i think about getting a new suspension setup im sure ill try to drive down to nj and have mikie take me for a drive so i can see how they feel. right now im on Epic springs (like Lokey) and KYB struts which im happy with the setup. theres a bunch of different options out there
  4. #33
    Oct 2012
    i was planning later down greatly improve the horsepower,brakes,suspension for weekends track use. i wanted to get a set up that i wouldn't have to change later down the road.. i was planning on spending good amount of money but i want coil overs for the street and track.. with regular guy and yellow spring its not adjustable though for the winter?isnt it a set height will it have just as good of a hadnling?
    Quote Originally Posted by mangostick View Post
    GTWORX.COM : GTWORX/Bilstein Impreza Cup Sport Kit for STI
  6. #34
    Aug 2012
    Tucson, AZ
    The best part about coilovers is they are adjustble
  7. #35
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by nsibanez View Post
    Which is absolutely useless since you need a suspension alignment ANY time an adjustment is made to the coilovers. Instead of wasting your money, you can just buy suspension that is matched to your goals.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  8. #36
    Aug 2012
    Tucson, AZ
    Never thought about that, but it does make sense.
    I was under the impression that it's only really necessary if you'r egoing obnoxiously low (There is such thing as too low)
  9. #37
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    Would you need an alignment if you just adjusted the dampeners?
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
  10. #38
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by maus View Post
    If you're adjusting just the dampening force, then you should not need one as long as it's not adjusting the ride height.
  11. #39
    Palmyra, NJ
    thinking about buying them since everyone say they are good...but are there better coilovers?
    There will always be better, but you're going to be paying more for better. If I had more money, I would have gone with KWs. But, I'm really happy with my Feals, and with the customer service Odi at Feal provided.
  12. #40
    zax
    zax is offline
    Nov 2008
    No, but the damping should be matched to the spring rate. I wouldopen a can of physics whoopass, but you are shooting for an overdamped system. If the damping is too high for the spring rate, you will have a critically damped system, which will not react correctly over bumpy roads. If the damping is too low for the spring rate, you will have an underdamped system, which will create a bouncy ride.
    Any change in ride height will affect your camber and caster. This will need to be adjusted for the best possible handling.
    Facebook me here
  13. #41
    Palmyra, NJ
    No...that just adjusts the rebound dampening. It doesn't change any height or actual physical components of the suspension.
    The Feals are 30 click adjustable (and the adjustability actually works well, unlike the BCs which have 30 click dampening as well, which owners say that every 6 or 7 clicks THEN makes a difference). You can specify whatever spring rates you want on the Feal coils when you order. I went with 7k/5k spring rates. You can go softer for more daily driveability if you'd like.
  14. #42
    zax
    zax is offline
    Nov 2008
    Mikie, make sure you are adjusting the damping with respect to the spring rates. They should be matched in accordance with manufacturer specifications. Running a high damping force with a low spring rate will give you dangerous handling. Have you discussed this with Feal?
    Facebook me here
  15. #43
    Palmyra, NJ
    I did discuss this with Feal quite a bit actually. They are valved to work with the spring rates even when adjusted. They have been preadjusted and set for optimum performance according to Feal.
  16. #44
    Oct 2009
    As mentioned, the Yellow spring cup kit from GTworx is for track/street. The Regular guy kit is for people like me who dont track their car but want a firm steetable setup.
    They've already done the track tuning for both setups with Bilstien.. I think they know what they're doing since they've been producing and selling dampers for oh I dunno a long effin time.
    Adjustability really doesn't mean much for a 90% street driven car. Seriously it doesn't. It sounds nice but when you realize how much you really dont mess with it you'll realize that you spent money you didn't have to spend. Or.. you get adjustable setups that aren't accurate or consistent. That's even worse. Why sacrifice accuracy or consistency over the ability to click a knob?
    Non-adjustables that are already matched are a bolt on and forget affair. Never need to mess with them again.
    fyi, the drop on the RCE/GTworx setup is only .75-1" .. that's not enough to sacrifice winter travels.
    SWP 2013 FRS
    SUCH IS MANGO!
  17. #45
    zax
    zax is offline
    Nov 2008
    Even then, though, (for anyone that remembers their DiffEq courses), there is a particular solution that best matches an overdamped condition with a transition threshold. As long as you remain within those ranges, you're at optimum damping.
    Facebook me here
