Good thread that someone on NASIOC pointed me to, as they had a similar question:
pink spring help!!! - NASIOC
Based on this, it appears that my rear springs may be STi v8 Tarmac springs with a rate of ~290lbs/in.
No new info on the fronts just yet.
This is a discussion on Help me identify these pink springs within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I just picked up a set of "STI pink" springs, and I'm trying to figure out just what I have ...
I just picked up a set of "STI pink" springs, and I'm trying to figure out just what I have as the paint markings don't seem to add up.
For starters, here's a picture from the seller of the springs:
I've found a TON of threads that mention that the JDM pink springs should have blue paint markings front and rear, yet only the rear springs in my set have a blue/light purple paint dab, with the fronts having a yellow paint dab.
Does this mean that I have the JDM rate rear springs and USDM/unknown rate front springs?
For reference, a few threads that I've found:
Identify these "pink" springs for me please, please, please!!! - Subaru Forester Owners Forum
CO: FS: JDM STI Pink Springs...used 280 miles / spring rates:257/217 - Subaru Impreza WRX STI Forums: IWSTI.com
FAQ: how can I determine real JDM pink springs/group-N tops? - Subaru Impreza WRX STI Forums: IWSTI.com
http://www.iwsti.com/images/faq/pinkspring_note.jpg
STi Pink Spring Rates - NASIOC
What'd the seller say they were?
If they are tarmac rear and USDM or even JDM fronts, I would not even consider running them in combination. Your rear rate at 290 is well above hte front rate of even the JDMs - that isn't going to work out well at all for the balance of the car.
The guy in that NASIOC thread BigSky is the one to listen to - he is also a moderator here.
PM BigSky - if he doesn't know no one does.
Thanks, I sent him a PM.
looks like these to me
-Clayton, Your official CLUBWRX Subaru Dealer!
CLUBWRX New car buying program SAVE HUGE on new Subarus:
http://www.clubwrx.net/forums/tri-st...ubwrx-net.html
Ask a Subaru Dealer thread:
http://www.clubwrx.net/forums/car-pu...ru-dealer.html
FREE 3rd party vehicle inspections:
http://www.clubwrx.net/forums/tri-st...spections.html
those appear to be Tarmac springs- orange dab front springs, blue/purple rear- great springs I ran them on my 04 WRX wagon, but they are firm (342/2985)- you need a good damper to run them (Koni), they will not be a good match w/ a "normal" damper
